Is the Big Bang Actually a White Hole?
The discussion explores the concept of whether the Big Bang singularity could be considered a white hole, examining the geometrical and physical distinctions between black holes and the Big Bang. Participants engage in theoretical reasoning, addressing the implications of different geometries in general relativity and the nature of singularities.
  • Some participants propose that it is reasonable to question if the Big Bang singularity is a white hole, while others assert that it is not, citing differences in geometry.
  • One participant notes that black holes are described by Schwarzschild geometry, whereas the Big Bang is described by Friedmann-Robertson-Walker (FRW) geometry, suggesting a fundamental difference.
  • Another participant emphasizes that white hole geometry is not isotropic and has distinguished directions, contrasting it with the homogeneous and isotropic nature of the Big Bang geometry.
  • It is mentioned that not all singularities are the same, highlighting the differences in tidal gravity and Weyl curvature between black hole singularities and the Big Bang singularity.
  • Some participants express a sense of coincidence between the concepts of black holes and the Big Bang, while others challenge this notion by pointing out the distinct geometrical properties.
  • There is a discussion about the nature of the universe's existence and whether it had a beginning, with differing views on the implications of the Big Bang and the possibility of an eternal universe.
Participants do not reach a consensus on the relationship between the Big Bang and white holes. There are multiple competing views regarding the nature of singularities and the geometry of the universe, with ongoing debate about the implications of these concepts.
Participants note that the definitions and properties of geometries can depend on various factors, such as the size and position of circles in different spaces, which may complicate the discussion of constants like π.
This discussion may be of interest to those exploring theoretical physics, general relativity, cosmology, and the nature of singularities in the universe.
rootone
TL;DR
big bang white hole
We know that black holes exist in the universe, but white holes don't, as far as we know,
Although white holes are not an impossibility in GR.
Is it reasonable to ask if the big bang singularity is in fact a white hole, and is the only white hole in the Universe?
Is the place where everything inside every black hole re-emerges as fundamental particles.
I'm sure somebody else must have considered that and according to some or another theory, it's not a very good idea
Or is it?
Space news on Phys.org
It's reasonable to ask, and the answer is no, it's not.
This is not what a white hole is.
Yes, and using the PF search feature to search for "big bang white hole" will turn up plenty of previous threads.
rootone said:
Summary: big bang white hole
No. It is a very different geometry than the early Universe.
OK, thanks both.
I know we are advised to not speculate here, so into the bin goes that idea.
I was never great at geometry anyway, 2D computer games always made more sense to me than 3D ones,
Black holes singularity and the big bang just seemed to me to be an unexplained coincidence,
But black holes apply to Schwarzschild geometry and the big bang applies to FRW geometry. And as to the apparent coincidence we don’t know the physical state in either case.
White hole geometry has distinguished directions (tangential, versus radial; thus not isotropic). It also distinguishes position (a translation generally produces a change in locally measurable tidal gravity). Thus it is also not homogeneous.
In contrast, the big bang geometry is homogeneous and isotropic everywhere. No positions or directions are distinguished.
A big distinction, don't you think?
Not all singularities are the same. A black hole singularity has tidal gravity--more precisely, Weyl curvature--increasing without bound as the singularity is approached. The big bang singularity has zero Weyl curvature. As has already been noted, they are very different geometries. The only thing they have in common is geodesic incompleteness, which is the definition of "singularity".
OK. thanks for helping.
So some coincidences are just that; coincidences.
I want to add that the above is true outside the horizon of a white hole.
Inside, you have an additional spacelike killing vector field, in addition to those defining spherical symmetry. As a result, spatial slices based on the KVFs provide homogeneity - translation anywhere on such hypercylinder simultaneity slice (of S2XR topology) leaves the metric unchanged.
However, then nowhere do you have isotropy. The tidal gravity at each point produces compression in the axial direction (of the additional killing vector field), and tension in the two orthogonal directions. [Note, this tension/compression is the opposite of the black hole interior, where the axial direction has tension].
This is a good example of how homogeneity does not imply isotropy.
Thanks.
It still seems to me too be a bit too much of a coincidence,
but then why is Pi what it is, and not some other number?
What is a coincidence? That the two geometries are fundamentally different and have very little to do with each other?
  • Haha
Are you operating on the assumption that ##\pi## is defined in terms of the ratio of the measured circumference of a circle divided by its measured diameter and that it is, thus, a property of the space that one inhabits?
The problem with such a definition is that in some (most?) spaces, it leaves ##\pi## undefined since there is no single ratio that holds for all circles. The ratio can depend on the size of the circle.
I believe that if you take the limit as the size of the circle decreases toward zero, you will get the mathematical constant ##\pi## in almost all cases.
... and the position of the circle.
On the last point, in all cases for smooth Riemannian manifolds. However, if you take the limit divided r3, so the units are inverse area, it converges to a constant related to Gaussian curvature.
It seemed to me to be a bit of a coincidance that geometrically we can describe space so that it is possible for things to just disappear and no longer be in the Universe as far as any observer is concerned, then at the same time, the Universe can start to exist, when any observer didn't see that before,
umm ... there were no observers before. This is again, a fundamental asymmetry. A BH horizon is never in the causal past, A WH horizon is never in the causal future. This latter means there cannot be an observer who "didn't see the WH, then later did".
The same is true of the initial singularity in FRW spacetime, which I think is what @rootone was referring to with "the Universe can start to exist".
Ok, thanks for your comments.
What I meant is that the Universe came into existence at some point, otherwise it would not be there.
I did not mean to imply that some "thing" enabled it to be so.
Not necessarily. It might have always existed--more precisely, it might have existed indefinitely into the past, with no beginning. We don't know for sure at this point.
So why is the Universe given an age, of about 14bn or so years?
This is not so certain?
That is the time since the Big Bang, which is the hot, dense, rapidly expanding state that is the earliest state of the universe of which we have good evidence. In inflationary cosmologies, it is the state at the end of inflation. It is not the "initial singularity", although many pop science treatments talk as if it is.
Let me point out that "singularities" in theories typically are not seen as physical but rather as regions where a more general theory is required, a sign that something is amiss in our description of Nature.
Well yes, I absolutely accept that.
In both cases there is a sign that something is amiss in our understanding,
and my question is in effect, can that misunderstanding be the same thing?
  • · Replies 19 ·
  • · Replies 20 ·
  • · Replies 25 ·
  • · Replies 22 ·
