Is the characteristic function constant everywhere if it is constant at 0?
3 replies · 4K views
wayneckm
Hi there,
Recently I have come across a proof with application of characteristic function.
After some steps in the proof, it concluded that there is a neighborhood of 0 such that the characteristic function is constant at 1, then it said the characteristic function is constant at 1 everywhere over the domain.
I suspect that "If there exists a neighborhood of 0 such that the characteristic function is constant, it is constant everywhere." Is this correct?
I have tried to search from the web regarding this but found nothing. Would anyone suggest me some good reference on characteristic function as well.
Thanks.
Wayne
Thanks.Wayne
It's true that
[tex]\varphi (0)=\int_{-\infty}^\infty f_{X}(x)dx=1[/tex].
However, I'm not aware that the ChF is constant anywhere for any PDF. Can you provide the source? Perhaps you are you talking about the (Dirac)delta distribution?
EDIT: The characteristic function is apparently defined differently in a non-probabilistic context. See the first paragraph of the following:
http://mathworld.wolfram.com/CharacteristicFunction.html
wayneckm said:
... it concluded that there is a neighborhood of 0 such that the characteristic function is constant at 1, then it said the characteristic function is constant at 1 everywhere over the domain.
An interesting generalization of the result is proved in Feller (vol 2 p 475), namely that any c.f. with constant absolute value is of the form [tex]\psi_X(t) = e^{ibt}[/tex], i.e. [tex]|\psi|=1[/tex] and the distribution of X is concentrated at b; moreover any c.f. that achieves absolute value 1 away from t=0 is periodic and represents a distribution concentrated on a lattice.
