Is the Earth in its original orbit?
  • Context: High School
  • Thread starter Thread starter scincemaniac
    Earth Orbit
The discussion revolves around the question of whether the Earth is in its original orbit, particularly in light of significant impacts such as the meteor that contributed to the extinction of the dinosaurs. Participants explore the implications of such impacts on Earth's orbital stability, considering both theoretical models and analogies.
  • Some participants propose that the impact of a large meteorite could have altered Earth's orbit, likening it to a bullet striking a surface, though this is presented as a personal theory.
  • Others argue that the mass difference between a meteorite and Earth is so vast that any change in Earth's momentum would be negligible, suggesting that the analogy used distorts the understanding of the impact process.
  • A participant provides a calculation indicating that a meteorite's impact would result in an imperceptible change in Earth's velocity, estimating it to be around 10µm/s.
  • Some participants reference the formation of the Moon as an example of a significant impact, questioning how such events affect Earth's orbital stability.
  • There are claims that geological and paleontological records indicate Earth's orbit has remained stable over billions of years, suggesting consistency in its orbital path.
  • Conversely, some participants assert that any impact, no matter how small, must have resulted in a change to Earth's orbit, even if infinitesimal.
Participants express differing views on whether Earth's orbit has changed due to impacts. While some suggest stability over billions of years, others contend that any significant impact must have altered the orbit, indicating a lack of consensus.
Discussions involve assumptions about the definitions of "original orbit" and the scale of impacts. The calculations and analogies presented rely on specific interpretations of momentum and impact physics, which remain unresolved.
scincemaniac
We know that the dinosaur was wiped out by a big meteor. Imagine a bullet hitting a hard surface,the Impact from the bullet should have moved the surface backwards right? So imagen that the meteor represent the bullet hitting the Earth and with that kind of impact it should have moved the Earth from its real orbit. Although this is just a theory that I have made and I want to share to everybody and see what do you think about it
Astronomy news on Phys.org
... and, have you done the math for this simple model? Conservation of momentum and all?
The question in the title isn't well defined as "original orbit"? can mean anything. The answer depends completely on the interpretation of the reader of those words.
But let's put that aside as you explained what you really meant in your post.The analogy in your post is understandable but it distorts a real understanding of the proces. The mass difference between the bullet and a steel plate is much, much smaller than the difference of a big meteorite and planet earth, even when the meteorite is 6 miles/10 kilometers in diameter. To use a better analogy, what would happen to the trajectory of such a big meteorite when you fire a bullet at it? Yes, it would alter the trajectory of the meteorite but only on a microscopic scale.
The same applies to the trajectory of Earth when a big meteorite strikes earth.
Let's assume Earth and the meteorite are both perfect spheres and both consist of the same (uniform) material. For simplicity assume the radius of Earth is 6000 km and the radius of the meteorite is 6 km. The meteorite is therefor 1/1000th that of earth. The volume of a sphere is 4/3 pi r3. The mass of the meteorite would therefor be 1/1,000,000,000 of the mass of the earth. You can find the formula for momentum on internet. Calculate what would happen to Earth's momentum when the meteorite strikes Earth head on. Then ask yourself what the effect will be om the momentum when Earth and the meteorite deform when striking each other.
Thanks mate this is useful for me to continue on my study :)
Quick estimate: 10 km/s at 1/1,000,000,000 the mass of the Earth changes our velocity by ~10µm/s. Orbits are closed ellipses, so the largest deflection from this velocity change is of the order of 6 months with a different velocity, for a difference of 10µm/s * 6 months = 160 meters. Completely negligible. Our orbit changes much more due to the gravitational forces of other planets (e. g. Jupiter: ~50,000 km as yearly variations).
We've also been struck by things far far bigger than the asteroid that killed the dinosaurs. The current theory of how the moon formed was that an object the size of Mars collided with earth. A lot of energy gets dispersed as shockwaves and heat. You envision a bullet hitting a bowling bowl and pushing it right? What about hitting a bullet-proof water balloon? The Earth is almost entirely liquid, not solid. We live on an eggshell, not a solid marble.
SciShow Space released this video yesterday on the topic
The geological and paleontological record suggests Earth has enjoyed a remarkably stable climate for billions of years. That is sufficient to assume Earth's orbit has been marvelously consistent for billions of years.
Goldilox in more ways than one, then.
No. While we have maintained a consistently survivable climate for billions of years, we could not possibly be in the exact same orbit as we were prior to the KT ELA. No matter how infinitesimal the difference, it's not possible. If we pass closer to Jupiter one year than the next, we are certainly being affected to some degree. More specific to your question, Math and Physics would say that the meteor MUST have changed Earth's orbit, again no matter how infinitesimally. We are still within the habitable zone and will likely remain that way until the death of Sol.
The solar luminosity increases slowly and the habitable zone shifts outwards. Within ~2 billion years we'll be outside the habitable zone, while the sun will continue to shine for ~5 billion years.
I'm well aware of that. I should have specified "until the death throes of Sol".
10K
  • · Replies 21 ·
  • · Replies 38 ·
  • · Replies 33 ·
