Is the numerical value of action functional of any importance?
The discussion revolves around the significance of the numerical value of the action functional in the context of classical mechanics, particularly when evaluating solutions to equations of motion. Participants explore whether the actual value of the action is important or if its variation is the primary concern, using examples from both theoretical and practical perspectives.
  • One participant questions the importance of the numerical value of the action functional, noting a case where the action evaluates to zero for a trivial solution.
  • Another participant clarifies that the action functional should be computed between fixed endpoints and points out that a zero value can occur without affecting the extremum of the functional.
  • A participant seeks examples of other functions where the minimum value is not zero, indicating a desire for broader understanding.
  • One participant provides an analogy using a parabolic function to illustrate that insisting on a minimum value of zero can lead to a specific case rather than a general principle.
Participants express differing views on the relevance of the numerical value of the action functional versus its variation. There is no consensus on whether the value itself holds significance beyond specific cases.
Participants note that the integrand can become zero in certain cases, which may influence the evaluation of the action. The discussion does not resolve the implications of these observations on the broader understanding of action in physics.
This discussion may be of interest to those studying classical mechanics, variational principles, or the philosophical implications of action in physics.
arroy_0205
While working out a problem I got a result which gave rise to this doubt regarding value of action functional. Suppose I start from an action, obtain the equation of motion and when I try to check if that solution gives a finite value of action, I get, surprisingly, vanishing value. The actual problem I was doing is a bit complicated to describe here, so take a simpler prob. Suppose for a particle,
<br /> S=\int dt \frac{1}{2}m\dot{x}^2<br />
One possible solution is, x(t)=constant. This is a trivial solution, but in the problem I am doing this kind trivial solution is enough. Now for this trivial solution, the value of action functional is zero. It looked strange to me. But then I thought may be the actual value of the action is not that important, what is important is its variation. Is that point of view valid? I would like to know your opinion. Of course the action does not show other undesirable features in my case. Do you think in such cases anything else should be carefully investigated? Thanks.
The functional should be defined as
S=\int_{t_1}^{t_2} dt \frac{1}{2}m\dot{x}^2
and computed between two points x_1=x(t_1) and x_2=x(t_2) keeping these points fixed. Then, you take all the possible paths between these two points and you uncover that the only one being an extremum of this functional is that solving Newton equation of motion for a free particle. Indeed one will have
S=\frac{1}{2}m\frac{(x_2-x_1)^2}{(t_2-t_1)}
but you are taking x_2=x_1 and for this particular solution one has indeed S=0.
The value of the action with respect to its extremum value is not relevant and can also be zero. This also happens to functions in a more mundane world.
Jon
Thanks for the reply. I get your point. Actually I din not put the limits of t because in this case even before I worry about the limits, the integrand becomes zero, since \dot{x}=0 in this special case. Since you are saying that this (ie, S=0) also happens in more mundane world, can you please cite other such examples briefly? It would be interesting to know.
The meaning of what I am saying is the following using a more mundane argument. Consider a parabolic function
y=x^2+kx
This function has a minimum at x_m=-\frac{k}{2} with the value of the minimum y_m=-\frac{k^2}{4} and this is quite general. But if you insist to demand the minimum in zero you are just selecting the particular case k=0. This is what happens for your case.
Jon
  • · Replies 0 ·
  • · Replies 20 ·
