Is the Provided Solution Correct for the Partial Fractions Decomposition?
The discussion revolves around a partial fractions decomposition problem involving the expression (4x+1)/(x+1)^2(x-2). The original poster is attempting to verify their solution against a provided answer from their university's physics department, which has led to confusion regarding the correctness of their approach.
  • The original poster describes their method of setting up the partial fractions and substituting values to solve for coefficients. They express uncertainty about their results compared to the provided answer. Other participants question the correctness of the original poster's setup, particularly regarding the use of denominators and the resulting expressions.
Participants are actively engaging with the original poster's reasoning, offering insights into potential mistakes and clarifying the structure of the partial fractions. There is a recognition of differing interpretations of the problem setup, and some guidance is being provided to help clarify the original poster's confusion.
There is mention of the original poster's reliance on memory due to not having access to textbooks, which may have contributed to their misunderstanding of the partial fractions setup. Additionally, the discussion reflects on the importance of correctly matching denominators in the decomposition process.
Hypochondriac
Im going to Durham uni in oct to do physics, and the nice people of the physics department sent me some maths questions to do before I arrive.
One of the partial fractions questions looked simple enough, but when I did it, I got it wrong...so with the answer they give, i worked back to the question, and they didnt match so I was wondering if it was something I did wrong, or something they did
the question was express (4x+1)/(x+1)^2(x-2) in partial fractions.
so i did the usual 4x+1 ≡ A(x+1)(x-2) + B(x+1)^2(x-2) + C(x+1)^3
then I chose to substitute x=2, as to eliminate A and B,
when I did this I got 9 = 27C, so C = 1/3
in the answer they wouldnve had C as 1.
Their full answer for the record was:
1/(x+1)^2 - 1/(x+1) + 1/(x-2)
but when substituting 1, -1 and 1 in for A B and C, I get 4x^2 + 4x +1 instead of just 4x+1...
whos wrong?
most of my answer came from memory seen as i gave my textbooks back to my old school.
and from what i remeber when there's a squared term ie (x+1)^2, in the partial fractions one has the denominator (x+1) and one has (x+1)^2
then i multiplied the letter with that denominator by the denominators it doesn't have.
so the (x+1)^3 came from C(x+1)(x+1)^2, as C had the (x-2) denominator.
which if i was to manually find a common denominator wouldn't make sense,
quess i shouldn't take shortcuts
i know where i went wrong now,
thanks!
I've just done the problem, and I get the same answer as Durham. I think I can see your problem, though. You seem to have multiplied the RHS by an extra (x+1) - I used to make that mistake too!
I'll try to show you why you don't need to multiply by the extra (x+1).
You correctly said that:
\frac{4x + 1}{(x+1)^2 (x-2)} = \frac{A}{(x+1)^2} + \frac{B}{(x+1)} + \frac{C}{(x-2)}
What you want to do is make sure the denominators of all of the fractions on the RHS are the same.
So, you need to multiple fraction "B" by (x+1)(x-2) so that it has the same denominator as the other two - by that I mean it has a (x+1)^2 like fraction A, and a (x-2) like fraction C. Then, you need to multiply fraction C by (x+1)^2 so that it contains the same numerator as B, and the same (x+1)^2 factor as A. Now, to make fraction A the same as the other two, you need to multiply it by (x-2). I hope this makes sense.
If we do it your way, we end up with:
\frac{4x + 1}{(x+1)^2 (x-2)} = \frac{A(x-2)(x+1) + B(x+1)^2(x-2) + C(x+1)^3}{(x+1)^3 (x-2)}
Which is correct (because the x+1 cancel on the RHS), but you can't say that;
4x+1 \equiv A(x-2)(x+1) + B(x+1)^2(x-2) + C(x+1)^3 because the numerators of the L- and R-HS are not the same.
I seem to have rambled on way too much, but I hope it's helped
Edit: Sorry, I got sidetracked, and ended up being posted way too late!
Okay, you know that
\frac{4x+1}{(x+1)^2(x-2)}= \frac{A}{x+1}+ \frac{B}{(x+1)^2}+\frac{C}{x-2}
and multiplying by that denominator, (x+1)2(x-2) gives
4x+ 1= A(x+1)(x-2)+ B(x-2)+ C(x+1)2.
No, that doesn't look right, even allowing for differences in what denominator A, B, C had. For one thing, since you only had (x+1)2 in the denominator, you can't have (x+1)3!
Starting from there, you will have, getting "common denominators"
\frac{x-2}{(x-2)(x+1)^2}- \frac{(x+1)(x-2)}{(x-2)(x+1)^2}+ \frac{(x+1)^2}{(x-2)(x+1)^2}= \frac{x-2- x^2+ x+ 2+ x^2+ 2x+ 1}{(x-2)(x+1)^2}= \frac{4+1}{(x-2)(x+1)^2}
as wished.
whos wrong?
Where did you get that (x+1)2 in the second term and and (x+1)3 in the last term?
  • · Replies 21 ·
