Is the sequence 1, 1/2, 2/3, 3/4, 4/5... compact?
  • Thread starter Thread starter cragar
    Compact Set
2 replies · 2K views
cragar
{1,1/2,2/3,3/4,4/5...} is this set compact.
I think this set is compact because it contains its cluster point which is 1.
is this correct?
You could prove that by appealing to "any closed and bounded subset of the real numbers is compact" or directly from the definition:
Let [itex]\{U_\alpha\}[/itex], for [itex]\alpha[itex]in some index set, be an open cover for this set. Since 1 is in the set, 1 is in at least one of those- relabel the sets, if necessary, so that set is called [itex]U_1[/itex]. Since [itex]U_1[/itex] is open, there exist a point p, in that set, and a number [itex]\delta> 0[/itex] such that [itex]N_\delta(p)= \{x | |x- p|<\delta\}[/itex] is in [itex]U_1[/itex]. It then follows that if [itex]n> 1/\delta[/itex] [itex]|1- (n-1)/n|= 1/n< \delta[/itex] so that all except a finite number of the fractions in the sequence are in [itex]U_1[/itex]. Every number in the sequence, [itex](n-1)/n[/itex] for n less than that might be in as separate set in the original sequence but there are only a finite number of them.[/itex][/itex]
