mrspeedybob said:
From a distant frame of reference a falling object never reaches the event horizon due to time dilation.
This is not incorrect, exactly, but it can be misleading, since it's tempting to draw inferences from it such as the ones you draw, which are incorrect.
mrspeedybob said:
If I drop a meter stick into a black hole lengthwise I should see both ends of the stick getting asymptotically closer and closer but never reaching the horizon
Does "lengthwise" mean oriented radially (i.e., vertically)? I'll assume it does in what follows, since otherwise the problem is much less interesting.
mrspeedybob said:
thus the stick should appear to get shorter from my frame of reference.
No, it won't. The apparent "time dilation" that a distant observer sees when watching an object fall into a black hole doesn't work the same as time dilation due to relative velocity. That's one of the main reasons I don't think applying the term "time dilation" in the gravity case is a good idea.
mrspeedybob said:
Assuming that the black hole is large enough that tidal forces are negligible then the stick should not experience anything abnormal
Correct.
mrspeedybob said:
therefore I conclude that the shortening of the stick is a relativistic length contraction type of phenomena.
This is one of those incorrect inferences that the term "time dilation" tempts you to draw.
mrspeedybob said:
This same logic should apply equally well to a stick of a kilometer or a light-year.
Even if the logic were correct, it wouldn't apply to a stick of arbitrarily long length, because at some point the stick's length would be comparable to the size of the black hole, and tidal forces would certainly not be negligible in that case. (The possibility of non-negligible tidal forces also has to be taken into account in the correct logic, which I'll describe in a moment.)
mrspeedybob said:
can I not conclude that the distance from myself to the event horizon is longer then any arbitrarily long stick?
No, and that's not just because of what I said just now about tidal forces becoming non-negligible when the stick is large enough. The key here is to carefully define what we mean by "distances" in the radial direction, and to recognize that what the distant observer sees is distorted by the curvature of spacetime, so it's not a good way to judge what is actually happening to the stick, as MrAnchovy pointed out.
To properly judge radial distances, the distant observer has to correct for the distortion in what he sees. He does this by using the radial metric coefficient, ##g_{rr}##, which is ##1 / (1 - 2M / r)##, where ##M## is the mass of the black hole. At any given instant of the distant observer's time, the stick extends from ##r_1## to ##r_2## (where we stipulate that ##r_1## is the smaller of the two), so its proper length is given by
L = \int_{r_1}^{r_2} \sqrt{g_{rr}} dr
If you work out this integral, you will see that it is finite for any values of ##r_1## and ##r_2## greater than ##2M##; in fact, it will be finite even in the limit as ##r_1 \rightarrow 2M##. That indicates that the distance from any ##r > 2M## to the horizon at ##r = 2M## is finite. (This is still true when the distance is large enough that tidal forces are not negligible; but in that case the range of ##r## coordinates occupied by the stick will be increased significantly as it falls once the tidal forces get strong enough, so its proper length will increase.)
