Is the Velocity Calculation Affected by Gravity or Elastic Potential Energy?
  • Thread starter Thread starter sacred76
    Ball Velocity
The discussion revolves around a physics problem involving the calculation of a ball's velocity after being released from a compressed spring. The problem includes concepts of gravitational potential energy and elastic potential energy, with specific values provided for the force exerted by the spring and the mass of the ball.
  • Participants explore different approaches to calculating the ball's velocity, including the use of energy conservation principles. Questions arise regarding the interpretation of the force applied and the relationship between gravitational and elastic potential energy.
Some participants have provided guidance on how to relate the energy stored in the spring to the kinetic energy of the ball. There is ongoing exploration of the assumptions regarding the forces involved and the effects of gravity on the calculations.
Participants express confusion over the definitions and relationships between force, energy, and velocity in the context of the problem. The original poster's calculations differ from the expected answer, prompting further inquiry into the setup and assumptions of the problem.
sacred76
The spring is compressed with a force of 30 N, calculate the ball’s velocity at point Q when the compressive force is released. The mass of the ball is 300g. (Ignore air resistance).
I used mgh = 1/2mv2
Hi all!
I was attempting the following question but my answer differed from the given answer. Please help me to solve it. Thanks.
My answer = 2.45 m/s
Given answer = 3 m/s
Welcome to the PF. :smile:
Can you show your work so we can check it?
Also, have you tried using an overall potential energy approach to solve this?
sacred76 said:
Problem Statement
I used mgh = 1/2mv2
Hi all!
What do you think the force of ##30N## involves? Is that the force on the spring? Or is that some force applied to the ball? Are these the same?
Do you want the velocity at point Q or the velocity when the ball is released?
Errr...I'm lost & confused :headbang:. Please teach me how to do it. TQ
I used mgh = 1/2mv2
Working : mgh = 1/2mv2
m x 10 x 0.3 = 1/2 x m x v2
3 = 1/2v2
v2 = 6
v = 2.45 m/s
I used mgh = 1/2mv2
3 = 1/2v2
v2 = 6
v = 2.45 m/s
At point Q, the work done by the spring will be shared between the gained GPE, mgh, and the gained KE. These need not be equal.
What you have found is the KE the ball would have if dropped from point Q to the shown starting position (but with no spring there).
Can you find the energy stored in the spring before release?
Is it 30 N? Sorry, I'm completely lost here as I can't really comprehend the above. Could you please show me the working/equation for me to digest?
sacred76 said:
Is it 30 N?
That's a force, not energy.
Calculate the value of the spring constant.
Is it using 1/2Fx?
Elastic potential energy = 1/2 x 30 N x (0.3 m)
= 4.5 J
sacred76 said:
Is it using 1/2Fx?
= 4.5 J
Yes, that does it. (If you did not know the Fx/2 formula you could get there by combining F=kx and E=kx2/2.)
So relate that energy to the situation at point Q.
Can I assume that it's Elastic potential energy = Kinetic energy which is 1/2Fx = 1/2mv2?
Don't you think that gravity might have something to say about that?
