Is there a maximum mass for a black hole?
  • #61
Drakkith said:
Neutrinos do not travel FTL. There was an error in the setup of the detectors and clocks. I believe one of the cables was incorrectly installed. And while neutrinos may be a type of dark matter, they are not the type that we normaly talk about if my memory is correct.
Are you making this up or did you get this from somewhere?
No, that was a faulty experiment.
Observations have been made and we have reason to believe that dark matter doesn't interact with normal matter. Look at the Bullet Cluster for example.
Sorry the neutrino thing was a joke too good to miss. The bullet cluster article raises some issues. As MACS J0025.4-1222 appears to have had its dark matter halo stripped it would be useful to observe effects on rotational velocity if any. Also if this halo reforms over time then the dark matter has to come from somewhere. Also what about the galaxy rotation problem?
Astronomy news on Phys.org
  • #62
I think you should work on your delivery.
The dark matter would come from already existing dark matter.
What about it?
  • #64
My god not a direct connection between dark matter halos and black holes! Whatever next?
  • #65
hubble_bubble said:
I don't see what this has to do with the rest of the thread. Please don't post just to post, it doesn't help the thread at all and will only make for a confusing conversation with multiple topics being discussed at one time.
  • #66
Well the original thread asked was there a maximum mass for a black hole. The article in the link brings into question how that mass is derived. It also implies that the dark matter halo inhabits a specific region around a black hole. So I think it should be considered pertinent to the thread topic. If the halo is proportional to the mass of the black hole then detecting the size of a galactic halo should allow calculation of the expected mass at the galactic centre.
  • #67
Also bear in mind that the halo is proportional to the size of black hole and not the mass of the galaxy it surrounds.
  • #68
If we have rs=2Gm/c2 as our Swarzchild radius then rs+n1 could be the lower bound of the halo and rs+n2 could be the upper bound. The gravitational constant and mass have to remain the same. To derive these new values then surely c must change under the conditions within and surrounding a black hole when considering dark matter. In fact I was wrong. c has to decrease in order to provide the range for n1 and n2. This is the ultimate result from light falling into the event horizon. The consequence of this would be a projected region of a proportional size to the mass of the black hole that would effectively trap the dark matter unless some galactic collision were to strip it away.
  • #69
Does anyone know if there are any detections of waves from around a black hole and what frequency range they are at?
  • #70
There is no known link between dark matter and black hole mass [re: Supermassive black holes do not correlate with dark matter halos of galaxies http://arxiv.org/abs/1101.4650] . It is also unlikely dark matter is a significant contributor to black hole mass because, unlike baryonic matter, it is essentially collisionless. Baryonic matter is slowed by collisions with other baryonic matter allowing it to shed angular moment and be captured by local gravitational wells [like black holes]. Ingesting large amounts of dark matter would also interfere with galaxy formation via a process called runaway accretion.
  • #72
I'll get back to you on that I have just had some very interesting thoughts.
  • #73
"We conclude that black holes do not correlate directly with dark matter. They do not correlate with galaxy disks, either. Therefore black holes coevolve only with bulges."
This implies rotational velocity as the bulge will form around a rotating black hole, presumably with significant velocity. Also accumulating an ergosphere where time and space behave in peculiar ways.
  • #74
One definite link is that dark matter does not cluster near a black hole. This would distort the galaxy it inhabits. I see your point though. They do say that it is "unless they contain a bulge". In this scenario the correlation has to be explained somehow.
Just a follow up I do not believe that the dark matter contributes to the mass of a black hole. I am just trying to work out how they are linked under certain conditions.
  • #75
just one fly in the ointment. If the event horizon stops anything at light speed or less escape the black hole how does gravity itself have an influence outside the EH. It travels at the sped of light. I know that this sounds like a very silly question to ask as it is self referencing, but that is a force that travels at the speed of light that violates its own bounds. We do not even know what gravity is but there could be a case for arguing that is should trap everything including itself.
  • #76
hubble_bubble said:
I have just looked up this article about quantum gravity.
http://www.sciencedaily.com/releases/2001/02/010212075309.htm
If the speed of light is frequency dependent then this could explain the position of the halo.
Since that article is over 11 years old and I've never heard of this before, I'm going to assume that no correlation has been observed yet. Nor do I understand how this could possibly explain the position of the halo.
I really don't think the rotation of the black hole has anything to do with the velocity of the bulge. The effect of the black hole's rotation just doesn't extend far enough out to do anything like this to my knowledge.
Gravity is in the geometry of spacetime, it is not something that has to "get out" of anything. Gravity WAVES travel at the speed of light, but gravity, meaning the geometry of spacetime, acts instantly. It is only the change in spacetime that moves at c.
  • #77
See http://curious.astro.cornell.edu/question.php?number=264/
  • #78
Thanks for the link. Interesting.
  • #79
I take your points. I have to say though that the prograde and retrograde photon orbits have set distances that can be calculated for a Scwarzchild black hole. For Kerr black holes the spherical orbits can also be described. These distances are proportional. Why then can this not extend further. We have gravity amplification in effect and an enormous mass. Since theoretically gravity extends to infinity the diminishing force has a curve plotted against mass and distance. In the normal universe outside the event horizon I would expect this to behave differently than when a black hole is involved.
  • #80
You can extend it further. It just has negligible effect due to the vast distances between objects in space. And I don't know what you mean by "gravity amplification", as such a thing does not exist. Gravity behaves no differently near a black hole than it does near any other object.
  • #82
Within the event horizon I would say that gravity is definitely amplified. Past the point of no return. BTW what mass would produce a Swarzchild radius equal to the Planck length and also to Planck length cubed?
  • #84
Then you are incorrect. Gravity is not amplified within the event horizon according to current theory.
  • #85
If you study the article in the link in #83 then this is what happens. Also mass is increased as if out of nowhere which is what I had found and didn't believe. This research ties cold dark matter to black holes.
  • #86
Simple: the Planck mass. Or maybe the Planck mass with a small prefactor, as those are arbitrary anyway.
  • #87
Have you looked at the work on Sagittarius A* where the milky way supermassive black hole is assumed to be located and also the work on dark matter detection in the milky way that has found NO evidence of halo effects? If the halo is in fact made up partly of primordial black holes then we are looking in the wrong direction completely.
  • #88
I need a cubed component for my calculations but it needs to relate to this Planck mass. I am not sure if this is simply the Planck volume. If it is then this ties in with quantum effects but what happens when this is scaled up?
  • #89
If we assume that matter at the singularity is contained within the Planck volume then plotting back from the Schwarzschild radius the escape velocity may well approach infinity. I need to think about that one.
  • #90
To account for this violation of relativity time must speed up and the mass is effectively thrown forward into the future. Time does not go backwards so bad news for time travel.
  • · Replies 17 ·
