Is there a more efficient way to do this?
  • Thread starter Thread starter Artusartos
    Statistics
6 replies · 2K views
Artusartos
Let X= [tex]\begin{bmatrix} X_1 \\X_2 \end{bmatrix}[/tex] be bivariate normal [tex]N(\begin{pmatrix} \theta \\ \theta \end{pmatrix}, \begin{pmatrix} 1 & u \\ u & \sigma^2 \end{pmatrix})[/tex]. Let [tex]T=aX_1 + (1-a)X_2[/tex].
a) Write u in terms of [tex]\rho[/tex] = the correlation coefficient, and [tex]\sigma[/tex]
b) Find the distribution of t
c) Find the value of a that minimized the variance of T.
a) [tex]\rho = u/\sigma[/tex] so [tex]u = \rho\sigma[/tex]
b) T is also normal...
If we write [tex]T = aX_1 + (a-1)X_2 = \begin{bmatrix} a & a-1\end{bmatrix}\begin{bmatrix} X_1 \\ X_2 \end{bmatrix}[/tex]
Let A=[tex]\begin{bmatrix} a & a-1\end{bmatrix}[/tex]
Then E(T)=AE(X)
Var(T) = A*covariance matrix*A'
So the distribution of T is N(E(T), Var(T))
Do you think this is correct?
c) I'm stuck here...
Thanks in advance
Then E(T)=AE(X)
Thanks in advance
You need to be careful: you need 1-a, not a-1.
Anyway, you know the mean of T and can get the variance using standard formulas, so you know the distribution of T without further work. You are doing it the hard way, and I do not understand what you are trying to do.
Thanks for pointing out that mistake...
The reason why I'm trying to find E(T) and Var(T) is so that I can write it as N(E(T), Var(T)). I know that it's normal but I'm trying to find the mean and the variance so I can write it in this form. I'm not sure if the professor wants this so I'm just doing it...just in case.
But is it ok if you give me a hint for part c?
You cannot minimize Var(T) until you have a formula for Var(T). As I said, just use standard results to get it.
After I computed Var(T) from Var(T) = A*covariance matrix*A', I set the derivative (with respect to a) to zero and solved for a...do you think that's correct?
How do you usually find maxima or minima of functions?
I set the derivative equal to zero and then I check if those points are maximum or minimum...
