Is there a solution to this simple 1st order PDE?
  • Thread starter Thread starter docnet
    Pde
16 replies · 2K views
docnet
please see below
please see below
This isn't homework, but I was just wondering whether the following PDE has an analytic solution.
$$\partial_x u(t,x)=u(t,x)$$
where ##x\in R^n## and ##\partial_x## implies a derivative with respect to the spatial variables.
If ##\ u = f(t)e^x\ ## then ##\quad \partial_x u(t,x)=u(t,x)##
Thank you BvU for preventing my headache. Just so that I'm understanding this correctly, did you define ##f(t)## to be an arbitrary function defined for ##t\in(-\infty,\infty)##, and you defined ##u(t,x)## for all of ##R^n##?
##u(t, x)## would be defined on some subset of ##\mathbb R^2##, not ##\mathbb R^n##
what about the case when ##x\in R^n## so ##u(t,x)\Rightarrow u(t,x_1,x_2,...x_n)##?
Can ##u(t,x)## be a short-hand way of writing the latter case?
It can be, but I'm not sure exactly what ##\partial_x## would mean in that case.
If it's the partial derivative with respect to each variable consecutively, then ##e^{\sum x_i}## still works.
thank you.. may i ask one more question ?
Is the solution ##e^{\sum x_i}## to the PDE ##\partial_xu(t,x)=u(t,x)## derived by a theorem?
we know the solution ##v=Ce^t## to the ode problem ##v'=v## is found by separating the variables ##v## and ##t## and integrating. is the PDE case analogous or much more complicated?
edit reason : clarity
I was mostly just copying the idea of the solution for the two dimensional case.
In general pdes are much harder to solve than odes are.
I suppose it could, but that would have to be given information. Since you didn't show any such information, it's really a stretch to make that assumption. And as Office_Shredder mentioned, it would be meaningless or at least ambiguous to talk about the partial with respect to x.
:olduhh: Aren't you just bamboozling yourself with notation? Isn't this just ##\dfrac {du}{dx}=u## ? For which the solution is ##u=Ae^{x}## - just the familiar exponential function or curve of ##u## against ##x##. With ##A## an arbitrary constant, determined by the 'initial' value of ##u## at any particular ##x##. Then this curve may be magnified or contracted as any extraneous variable, call it ##t##, changes any which way. Think of this as changing the initial condition in any which way and represent it: ##u=A(t)e^{x}## .
I'm sorry about that. not making excuses, but my PDE professor likes to use the short-hand? the description ##x \in R^n## to mean ##x=(x_1,x_2,...,x_n)##. ##u(t,x)## means ##u(t,x_1,x_2,...,x_n)## and ##\partial x## means partial derivatives with respect to each spatial variable consecutively. His notations have caused confusion for I and other classmates before, but we got familiar to them over time. The professor likes to think in abstract terms and use abstract notations whenever possible. I realize his notations are not usual.
wow, I think you make a great point. suppose ##x\in R^n## where ##n>1##, then how will your description change to account for extra spatial variables? thanks, I will chew on this over night.
We can make the change of variables ##x_1=u+v## and ##x_2=u-v##. Ignore t and pretend we're doing it in two dimensions.
Then ##\partial_{x_1}=\partial_u+\partial_v## and ##\partial_{x_2}=u-v## so ##\partial_x =\partial^2_u+\partial^2_v##. This means once we have any particular solution, we can add homogenous solutions which are harmonic functions. There are a lot of them, for example the real and imaginary part of any complex differentiable function are both harmonic.
I humbly concede that I totally overlooked the possible vector character of ##x## (and possibly also the vector character of ##u## :rolleyes: ?) because I am so used (spoiled rotten?) to a clear distinction in notation: either ##\bf x, \ \bf u## or ##\vec x, \ \vec u## -- used consistently -- denote vectors; ## \ \ x, \ u## denote scalars. Even then, ##\ \displaystyle {\partial\over\partial\vec x} ## is to be avoided in favor of ##\ \nabla\ ## or even ##\ \vec\nabla\ ##
##\nabla\cdot\vec u\ ## is unambiguously a scalar, and ##\nabla u\ ## is unambiguously a vector.
The Jacobian ##\nabla \vec u\ ## is a matrix and personally I prefer ##\ \vec\nabla\vec u\ ##
(but I still have to find a way to make it look reasonable : ##\vec \nabla \vec{\vphantom{\nabla}u}## is ugly too :biggrin: )​
@Office_Shredder saves my skin in #6 and you explain how this can pop up in #11. I sympathize but can't help and can't force PDEprof to share my preferences.
What remains in my perception is that PDEprof does do harm using ##\partial _x## this way: acting on a scalar it yields a vector that doesn't look like one and, by the same token: acting on a vector that looks like a scalar it yields a matrix that looks like a scalar (or a vector) too.
And now I must chew on #12 because I don't understand it ... :cry:
Man I don't understand this at all...Can you flesh it out for the slow kids? Sorry
In which case I would want to see an index: ##\ \partial_{x_i} \ ##
$$\partial_{x_i} u(t,x)=u(t,x)$$meaning
$${\partial u(t,\vec x)\over \partial x_i}=u(t,\vec x)$$
Or does "derivative with respect to each spatial variable consecutively" mean [tex]\frac{\partial^n}{\partial x_1 \cdots \partial x_n}[/tex] which makes [tex] \frac{\partial ^n u}{\partial x_1 \dots \partial x_n} = u[/tex] make sense for scalar or vector [itex]u[/itex]. This can be solved by separation of variables.
That's good you don't, because it was full of mistakes
Ok, consider the change of variables
##u=x_1+x_2##, ##v=x_1-x_2## (not the change of variables I said, I flipped it)
Then by the chain rule, ##\frac{\partial f}{\partial x_1}= \frac{\partial f}{\partial u} \frac{\partial u}{\partial x_1} + \frac{\partial f}{\partial v} \frac{\partial v}{\partial x_1}##
The partial derivatives of ##u## and ##v## are just 1 of course.
Which I will rewrite in the notation of the original post as ##\partial_{x_1} = (\partial_u+\partial_v)##
Similarly, ##\partial_{x_2} = (\partial_u-\partial_v)##
Notice that these partial derivative operators just multiply like ##\partial_x \partial_y## is the partial derivative with respect to y, then with respect to x (and these commute).
So ##\partial_{x_1} \partial_{x_2} = (\partial_u+\partial_v)(\partial_u-\partial_v)##.
Expanding the right hand side gives ##\partial^2_u+\partial_v\partial_u - \partial_u \partial_v - \partial^2_v##. The middle two terms cancel, leaving us with ##\partial^2_u - \partial^2_v,## (not the plus sign I promised)
Then I made a mistake, since I forgot ##u## showed up on the right hand side. If you had ##\partial_x u = f(x)## and you had some solution ##u_f##, then every given any solution of ##u_x =0##, say ##u_0##, then ##u_f+u_0## is a solution to ##\partial_x u =f(x)##. But this differential equation isn't in that form so that's not a useful observation.
My apologies for the mistakes.Edit to add:
I realize there are some simple solutions to this of the form ##f(u)+g(v)##. Then we get ##f''(u)=f(u)## and ##g''(v)=-g(v)## so anything like ##Ae^u + B e^-{u} + C \cos(v) + D\sin(v)## is a solution. To translate back to x coordinates, ##Ae^{x_1+x_2}+Be^{-(x_1+x_2)}+ C \cos(x_1-x_2)+D\sin(x_1-x_2)## are all solutions of the two dimensional equation (I'm still ignoring ##t##n from the o.p., since you can throw in functions of ##t## wherever you would have an arbitrary constant)
