Is there a specific unit used to measure redshift?
5 replies · 5K views
ASmartDude
i have been learning about using redshift to measure the distance of far-flung objects, but in all my research i never saw a specific unit used to quantify how redshifted an object is. to me it seems like an oversight, because such a unit would be very useful for the study of distant galaxies, and which the impending launch of the james webb telescope and the E-ELT project underway (i think), it seems to me such a unit would be needed for these tools to be properly used. so has anybody bothered to quantify redshift, or am i the first person to think of this?
Astronomy news on Phys.org
Redshift in cosmology is usually labeled as 'z'. It is unit-less because you divide the units out when you compare the observed wavelength to the known source wavelength. So if we observe a wavelength of 1,000 nm from a source that we know must have emitted 500 nm light, then ##z=\frac{1000 nm}{500 nm}=2##.
Redshift is based on a ratio between wavelengths. As such it is dimensionless and does not need a unit.
The definition is ##1 + z = \lambda_o/\lambda_e##. For your example, the redshift would be ##z = 1## and ##z = 0## corresponds to no redshift at all.
that makes sense. i thought i was onto a big discovery, but i guess not. thanks for the help!
The distance, by the way, is calculated based upon a model of how the universe has expanded over time. There are some online calculators that will do this, such as this one:
http://www.astro.ucla.edu/~wright/CosmoCalc.html
It's unfortunately complicated, because distances are pretty complicated in an expanding universe.
Ah, my mistake. Thanks, Oro.
