Is there a way to disrupt air molecules?
  • Context: Undergrad
  • Thread starter Thread starter frozenguy
    Air Molecules
The discussion focuses on the feasibility of disrupting air molecules around an object using electrical fields or creating a vacuum. Participants explore concepts such as the "plasma window," which acts as a barrier to gases but is not suitable for the desired application. The consensus is that current technology does not allow for the creation of a vacuum in mid-air or the effective repulsion of air molecules without a physical barrier. The conversation highlights the limitations of existing methods and the need for further research in this area.
  • Understanding of plasma physics and its applications
  • Familiarity with vacuum technology and its principles
  • Knowledge of electromagnetic fields and their interactions with gases
  • Basic principles of gas dynamics and molecular behavior
  • Research the principles of plasma windows and their applications in gas containment
  • Explore advanced vacuum technology, including vacuum pumps and chamber design
  • Study electromagnetic field generation and its effects on gaseous molecules
  • Investigate gas dynamics and methods for measuring gas density and pressure
Researchers in physics, engineers working on advanced materials, and anyone interested in the manipulation of gases and vacuum technology.
frozenguy
I want to know if there is a way to push or disrupt air molecules around an object, or the device. Like some time of electrical field maybe?
How would one attempt to go about creating a space evacuated of air around the device, with a field, or a vacuum nearing evacuation.
You would pretty much have a force-field if you did that, I don't think there is any way to do that reasonably.
What do you mean by a force-field? Don't generate fields with electromagnetics? Those have forces.
Well can someone point me in the direction of where one could start?
How can you manipulate gaseous molecules of N, and O?
More importantly, how would one measure a result like this? You could have tubes at different heights off the surface of the device that ran to barometer's.
Actually, just use this "http://en.wikipedia.org/wiki/Plasma_window" and your set. It is a force field for all intents and purposes!
Well, I'm thinking more along the lines of just repelling the gaseous atoms away from the device, in all directions. Like a short distance, x. a few cm, half a meter, I dunno.
The plasma window is interesting but it has plasma on the outside which I don't think I want in this experiment.
Yeah, you wouldn't want to hold it for too long.
If you need a device that repels air strongly enough to hold a good vacuum while not repelling your hand at all your going to need to do some research for a while.
The ideas being talked about here are just not possible with current technology.
Vacuums can be created inside rigid-walled vessels, but there is no way to just repel air molecules and create a vacuum in mid-air, so to speak.
  • · Replies 21 ·
  • · Replies 27 ·
  • · Replies 42 ·
12K
