Undergrad Is There an Absolute Maximum Density for Substances?
  • Thread starter Thread starter Cody Wall
    Absolute Density
There is a discussion about whether there is an absolute maximum density for substances, with black holes cited as examples of objects with maximal density relative to their size. It is noted that adding energy to a black hole causes it to grow, resulting in larger black holes having lower density. The conversation also touches on the minimum distance between particles, suggesting that this distance influences density considerations. Below the Planck length and above the Planck density, meaningful statements about density become problematic. Overall, the topic explores the limits of density in physical systems.
Cody Wall
This is kind of a random question. Is there a point that a substance density will max out? Or in other words that it cannot be compressed any further no matter the energy you add to the system?
You could consider black holes as “objects” with the maximal density for their size. If you put in more energy they grow. Larger black holes have a lower density, although that concept is a bit tricky as they don’t have a well-defined interior volume.
@mfb I think we should "see" what's the minimum distance between 2 particle. I think it will also affect if we are talking about atoms or other particles (such as electrons...)
Below the Planck length (and above the Planck density) we can't make meaningful statements any more.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
  • · Replies 17 ·
11K
  • · Replies 21 ·
