Is there any way to simplify my proof by induction?
The discussion centers around simplifying a proof by induction for the statement ##n^2 + 1 < n!## for ##n \geq 4##. Participants explore various approaches to the proof, including direct methods and the use of the gamma function, while also addressing potential errors in arithmetic and reasoning.
  • One participant presents their proof by induction and seeks simplification for the inductive step.
  • Another participant argues that induction may not be necessary and suggests a direct approach to prove the statement.
  • Some participants point out arithmetic errors in the original proof, but there is disagreement on the specific lines where these errors occur.
  • A suggestion is made to use the gamma function to demonstrate the growth of factorials compared to polynomials.
  • One participant proposes a simpler version of the original proof, indicating that the inductive hypothesis complicates the argument.
  • There is a request for clarification on a specific inequality involving factorials and division by n, leading to further discussion on the reasoning behind it.
Participants express differing views on the necessity and effectiveness of using induction for this proof. While some suggest that induction complicates the argument, others defend its use. There is no consensus on the correctness of the arithmetic presented, as multiple participants identify errors but disagree on their locations.
Some participants mention potential arithmetic errors without resolving them, and there are unresolved questions regarding the clarity of certain inequalities and their implications.
murshid_islam
TL;DR
My proof by induction looks way too contrived. Is there a way to simplify it?
I'm trying to prove the statement ##n^2 + 1 < n!## for ##n \geq 4##. My proof by induction looks way too contrived. Is there a way to simplify it? Here's what I got.
For n = 4, ##n^2 + 1 = 17 < 4!##. So, the statement is true for n = 4. Now let's assume it's true for n = k, that is, ##k^2 + 1 < k!##
Now, for n = k+1,
##(k+1)^2 + 1 ##
##= (k^2 + 1) + 2k + 1##
##< k! + 2k + 1## ; [from the induction hypothesis for n = k]
##< k\cdot k! + 2k + 1##
##= (k+1-1)k! + 2k + 1##
##= (k+1)k! - k! + 2k + 1##
##= (k+1)! + 2k + (1 - k!)##
##< (k+1)! + 2k - k^2## ; [because 1 – k! < –k2 from the induction hypothesis for n = k]
##< (k+1)! + 0## ; [2k – k2 = k(2 – k) < 0 for k > 2]
Therefore, we have ##(k+1)^2 + 1 < (k+1)! ##
I was wondering if there's an easier way to do the n = k + 1 part.
Mathematics news on Phys.org
It doesn't seem like a good example of induction, as you don't really need the inductive hypothesis. If we look for the cases where ##n^2 + 1 \ge n!##, then we have ##n + 1 \ge n + \frac 1 n \ge (n-1)!##.
Now, if ##n \ge 4##, then ##(n-1) \ge 3## and ##(n-1)! \ge 2(n-1)##. So we can look for ##n## such that: ##n +1 \ge 2n - 2## and so ##n \le 3##, which contradicts ##n \ge 4##.
You could, of course, logically use this in the inductive step. But, it shows that induction itself is not very helpful in this case.
Your presentation has arithmetic errors.
Another way is to go continuous, using the gamma function.
$$n!= Γ(n+1)$$
the gamma function is known to grow very fast. So we can assume that at some value of x the factorial will be above any polynomial.
You can try to solve the equation numerically,
$$ Γ(x+1) = x^2+1 $$
Using python scipy root_scalar, I get the result 3.6467225149185953
Can you point out at which line? I can't find them.
Now, for n = k+1,
##(k+1)^2 + 1 ##
You want the next inequality to be ##< (k + 1)!##
If you can show that ##(k + 1)! - k! - 2k - 1 > 0## that's equivalent to saying that ##k! + 2k + 1 < (k + 1)!##.
The first inequality above is equivalent to ##k!(k + 1 - 1) - 2k - 1 > 0##, or ##k! \cdot k - 2k - 1 > 0##. That should be fairly easy to do.
##(k+1)^2=k^2+2k+1## (secod line)
This can be written as ##(k^2+1)+2k## .
Therefore, no error at that point.
That line (k + 1)2 + 1 was expanded and rearranged as k2 + 1 + 2k + 1.
murshid_islam said:
TL;DR Summary: My proof by induction looks way too contrived.
It may be worth re-emphasising that using induction itself is contrived in this case and that's partly why the inductive step gets messy. It looks more natural to prove directly that$$n^2 + 1 < n!$$rather then$$k! + 2k + 1 \le (k+1)!$$In other words, using the inductive hypothesis makes things harder.
I did not get this part: ##n + \frac 1 n \ge (n-1)!## Can you elaborate?
I divided through by ##n##. I didn't realise that might seem so obscure!
I had a brain fart.
By the way, here's a simpler version of my original proof:
For ##n = k+1##,
##(k+1)^2 + 1 ##
##< k \cdot k! + k^2 + 1##
##< k \cdot k! + k!## ;[from the induction hypothesis for n = k]
##= (k+1)!##
