Homework Helper
- 3,447
- 3,747
The closest thing to an "absolute measurement" like quantity I can think of off the top of my head is our current practical method of time keeping.Hacker Jack said:To want to know the exact quantity of an object whether it be it's length, width, weight etc... Doesn't an absolute measurement only exist in the math/our human Minds. Then go down to quantum scales and that gets even harder because from what point do we even measure from if there is no exact point (I think). Hopefully this is considered mainstream. Thanks in advance.
Some background before we discuss the practical stuff:
Before I get into the practical, let me briefly mention the theoretical. By our current definition of the second, 1 second is now defined as the time it takes a Cesium-133 atom at the ground state to oscillate exactly 9,192,631,770 times. Now we're back into counting. But let's not dwell on the counting part.
More to the point, if you have an atomic clock near a dense mountain it will tick slower than one away from dense mountains, all else being the same (elevation etc.) due to gravitational time dilation. Similarly, if you have an atomic clock at a higher elevation it will tick slightly faster, also due to gravitational time dilation. And yes, these atomic clocks are so incredibly "accurate" (so to speak -- more on that in a moment), that they can detect small changes due to relativistic effects. The point here is that even with incredibly accurate atomic clocks, they will measure time slightly differently depending on such things as their locations and speeds.
And even with relativistic effects aside, a given atomic clock is not perfect and will have uncertainty and variation due to thermal effects (it's not possible for the cesium-133 to reach absolute zero), if for no other reason. And then there's the inherent uncertainty at the quantum level. So theoretically speaking, even our atomic clocks are not perfect.
So that's all I have to say about the theoretical. Things get a little different once we start talking about the practical.
Practical aspects of time keeping:
Presently, the International Bureau of Weights and Measures combines the output of about 400 atomic clocks in 69 laboratories scattered around the globe, to form International Atomic Time (TAI). That, together with possible leap-seconds based on variations in Earth's rotation, is used for form Universal Coordinated Time (UTC).
That brings us to the gist of my point: For all practical purposes the length of a second is whatever time it takes for the TAI time to advance 1 second. That's the closest thing to a practical, commonly accepted, "absolute measurement" that exists in our world today. (At least the closest thing that I can think of.)
To pound home the point, if, hypothetically, for some weird reason, system of atomic clocks used to measure TAI time started ticking slower, then pretty much all official time as we know it -- GPS satellites, your cell phone's clock, your computer's clock, pretty much everything -- would soon synchronize up and would also start displaying time at a slower rate. (At least until UTC started manually playing around with leap-seconds, but that wouldn't change the official flow of time in-between leap seconds.) The unit of the second in SI units, which is also based on this, would change too, accordingly.
So for all practical purposes, the system of atomic clocks in TAI (or UTC if you want to include leap seconds) define the units of time. Sure, there are measurements and practical aspects involved, but that's about as close to an "absolute measurement" as you can get.
It gets a little weirder too.
The speed of light is no longer a measured quantity; it is now defined. The speed of light is, by definition, 299792458 meters per second. Exactly. No more; no less. One does not "measure" the speed of light anymore. It's defined. You just look up the number.
Instead, if you want to know how long an object is, you bring the object into the laboratory and measure the time it takes for light to pass from one end of the object to the other, multiply that time by the speed of light (299792458 m/s), and Bob's your uncle, you have the length.
This has some interesting implications. Going back to our hypothetical scenario where the atomic clocks in the TAI would slow down for some weird reason, it would also cause the official length of meter sticks to
