Is This Natural Language Proof of a Set Theory Proposition Correct?
The discussion revolves around proving the set theory proposition that A is a subset of B if and only if the intersection of A and B equals A. The proof is presented in two parts: first, it shows that if A is a subset of B, then the intersection A ∩ B equals A; second, it argues that if the intersection is not A, then A cannot be a subset of B. Participants provide feedback on the proof's clarity and correctness, noting the need for precise logical connections and definitions. There is also a request for help in translating the proof into formal language, indicating a desire for deeper understanding. The conversation highlights the importance of rigorous definitions and logical reasoning in set theory.
WisheDeom
Hello,
I am teaching myself Set Theory, and in doing some exercises I came across the problem:
Given sets A and B, prove that A \subseteq B if and only if A \cap B = A.
My proof, in natural language, is in two parts:
1) Prove that if A \subseteq B, A \cap B = A.
By the definition of subsets, all elements x \in A are also x \in B. By definition, A \cap B = \left\{x: x \in A \wedge x \in B \right\}. Since all elements of A are also elements of B, but not all elements of B are necessarily elements of A, the intersection fo the two is A.
2) Prove that if A \cap B \neq A, it is not true that A \subseteq B.
If the intersection of A and B is not A, then there are necessarily elements of A that are not elements of B, therefore A is not a subset of B.
Therefore, A \subseteq B if and only if A \cap B = A. Q.E.D.
Is this a sufficient proof?
If it is, could someone help me translate it into the language of formal language?
Edit: Fixed wrong logical connective, set notation.
Hi WisheDeom! :smile:
WisheDeom said:
Hello,
Given sets A and B, prove that A \subset B if and only if A \cap B = A.
1) Prove that if A \subset B, A \cap B = A.
By the definition of subsets, all elements x \in A are also x \in B. By definition, A \cap B = {x: x \in A \vee x \in B}.
Here you probably mean \wedge and not \vee.
This only proves that A\subseteq A\cap B? What about the other inclusion?
2) Prove that if A \cap B \neq A, it is not true that A \subset B. If the intersection of A and B is not A, then there are necessarily elements of A that are not elements of B, therefore A is not a subset of B.
You again use that A\cap B\subseteq A, you may want to prove this.
Therefore, A \subset B if and only if A \cap B = A. Q.E.D.
The proof looks good except for the remarks I posted.
I like the style of the proof. What do you mean with "formal language"? You mean with symbols like \Rightarrow,~\forall,~\wedge and stuff?
Unless I'm missing something, this theorem isn't true. It's almost true, but consider the case where A = B.
The theorem is true even in the case where A=B
Thank you for the responses.
Yes, of course.
This is what I was trying to do in the second part, but see below.
Would you be able to go into a little more detail? I know this is very basic, but I am just starting. :smile:
Yeah, that's what I meant. I guess my approach in learning the subject is a bit of a mix of "naive" and "axiomatic" set theory.
Yes, of course, I should have written "a subset of or equal to". I fixed the notation in the OP.
You say
But the only thing I can infer from the statement "If the intersection of A and B is not A" is that there either is an element in A but not in A\cap B or there is an element in A\cap B, but not in A. One of these possibilities cannot happen, namely that there is an element in A\cap B but not in A. But for that you need to show first that A\cap B\subseteq A
Ah! I understand now.
So by definition A \cap B = \left\{x:x \in A \wedge x \in B } and C \subseteq A \leftrightarrow \forall x (x \in C \rightarrow x \in A). Since the intersection of A and B contains elements from A but no elements not in A, (A \cap B) \subseteq A.
Is this valid? Does it complete the proof?
Thanks for your patience, by the way.
Yes, this is ok :smile:
WisheDeom said:
Hello,
Here is the formalization (ignoring tex):
Key:
A. for \forall
-> for \rightarrow
e. for \in
i^i for \cap
C_ for \subseteq
1 A C_ B <-> A. x ( x e. A -> x e. B )
2 ( A i^i B ) = A <-> A. x ( ( x e. A /\ x e. B ) <-> x e. A )
3 ( A C_ B <-> ( A i^i B ) = A ) <-> ( A. x ( x e. A -> x e. B ) <-> A. x ( ( x e. A /\ x e. B ) <-> x e. A ) ) ) (By 1 and 2)
4 ( ( x e. A /\ x e. B ) -> x e. A ) [case of a and b -> a]
5 ( x e. A -> x e. B ) -> ( x e. A -> ( x e. A /\ x e. B ) )
6 ( x e. A -> x e. B ) -> ( ( x e. A /\ x e. B ) <-> x e. A ) (By 4 and 5)
7 ( ( x e. A /\ x e. B ) <-> x e. A ) -> ( x e. A -> ( x e. A /\ x e. B ) )
8 ( x e. A -> ( x e. A /\ x e. B ) ) -> ( x e. A -> x e. B )
9 ( ( x e. A /\ x e. B ) <-> x e. A ) -> ( x e. A -> x e. B ) ( by 7 and 8)
10 ( x e. A -> x e. B ) <-> ( ( x e. A /\ x e. B ) <-> x e. A ) ( by 6 and 9)
11 A. x ( x e. A -> x e. B ) <-> A. x ( ( x e. A /\ x e. B ) <-> x e. A ) (by 10)
12 A C_ B <-> ( A i^i B ) = A (by 11 and 3)
Too much detail, but it is very spelled out.
