Is this sequence convergent or divergent?
  • Thread starter Thread starter cue928
    Series
4 replies · 2K views
cue928
For the following sequence of numbers {1, 1/3, 1/2, 1/4, 1/3, 1/5, 1/4, 1/6,...} determine if it is convergent or divergent.
Since several numbers appear more than once, my initial thought was that it did not converge. But, the numbers are getting smaller. So I thought to proceed with coming up with a formula for the denominator but was unable to find one. I've done this on several others with no problem but did not see it on this one.
Hi cue928, :smile:
How rigourous does your proof need to be?
Firstly, do you see what the denominators do in this sequence? It always goes +2, then -1, then +2, then -1,...
Thus, you start with 1
+2, then you get 3
-1, then you get 2
+2, then you get 4
-1, then you get 3
Your guess was indeed correct, this sequence keeps on getting smaller, and hence converges to 0. But again, how rigourous does this need to be?
See I don't know. For example, one of the problems was an=n^3 / (n+1). It sufficed there to divide thru by n, take the limit, and we're done. So I don't know if they even wanted a proof in the true sense of the word. My guess is that I need to provide something more than intuition.
Is there a formula that would yield that sequence of numbers? I tried but could not find it. I did have the +2, -1...differences that you showed.
Note that this is a sequence (terms listed with commas), and not a series (terms added).
You can come up with a formula, but you have to break it into even and odd terms, and you can get a formula in terms of n if you look at the odd terms a_{2n+1} and the even terms a_{2n} separately. That might be more than you are asked to do though - have you seen things like that in class?
Well, you could start by noticing that the odd indices form a sequence 1/n. Thus [tex]x_{2n-1}=1/n[/tex] for n starting with 1.
The even indices also behave as 1/n, but a bit shifted, thus [tex]x_{2n}=1/(n+2)[/tex], for n starting with 1.
This gives you a nice formula...
