Is this series divergent or convergent?
The series ##\sum_{n=1}^{\infty }1+(-1)^{n+1} i^{2n}## is convergent, with the sum equal to zero. The analysis involved applying the n-th term test for divergence, leading to the conclusion that the limit of the series as ##n## approaches infinity results in a constant oscillation between -1 and 1, ultimately simplifying to zero. The discussion clarified the importance of evaluating the summands before considering the overall sum.
  • Understanding of complex numbers and their properties
  • Familiarity with series convergence tests, particularly the n-th term test
  • Knowledge of limits and their application in series analysis
  • Basic algebraic manipulation of series terms
  • Study the properties of complex series and their convergence criteria
  • Learn about the Dirichlet test for convergence of alternating series
  • Explore the concept of uniform convergence and its implications
  • Investigate the implications of the n-th term test in various series
Mathematics students, educators, and anyone interested in advanced calculus or complex analysis, particularly those studying series convergence and divergence.
TheoEndre
3. The Attempt at a Solution [/B]
I tried using the divergent test by taking the limit as ##n## approaches ##{\infty }##, but both ##i^{2n}## and ##(-1)^{n+1}## will alternate from ##-1## to ##1##, while when I write the first terms, I get ##0## and that's what made me confused.
Using the n-th term test for divergence, the problem boils down to finding ##\lim_{n \to \infty}\left(1 + (-1)^{n + 1} \cdot i^{2n}\right) = 1 + \lim_{n \to \infty} \left((-1)^{n + 1} \cdot i^{2n}\right)##
It's true that the two factors in the last limit oscillate, but can you determine whether the last limit actually exists? Look at two cases: 1) n is even, and 2) n is odd.
I suggest working a bit with the expression inside the sum ...
I think I get it. For both cases the result will be ##-1##, so last limit would be ##-1## and we'll end up with ##0##, correct?
You'll end up with 0 for the last limit I showed, yes. So ##\lim_{n \to \infty}\left(1 + (-1)^{n + 1} \cdot i^{2n}\right) = 1 + 0 = 1##. Can you conclude anything from the n-th term test for divergence, or will you need to use some other test?
This is not correct. The second limit is the limit of a number of modulus one. It cannot possibly be zero.
You actually do not need any limits at all. Each term is identically zero.
Actually, I meant this ##\lim_{n \to \infty} \left((-1)^{n + 1} \cdot i^{2n}\right)## to equal ##-1## which means ##\lim_{n \to \infty}\left(1 + (-1)^{n + 1} \cdot i^{2n}\right) ## will equal zero.
I thought about that too. But the divergence test of it made me a bit confused.
Before you consider the sum, consider the summands. ##a_n=1+(-1)^{n+1}i^{2n}## can be simplified a lot. After done that for an arbitrary ##a_n##, only then start to think about ##\sum_n a_n##.
I am not seeing it.
Regarding the product, if n is an even integer (=2m), ##(-1)^{2m + 1} = -1## and ##i^{2(2m} = 1## with a product of -1.If n is an odd integer (= 2m + 1), ##(-1)^{2m + 2} = 1## and ##i^{2(2m + 1)} = i^{4m + 2} = -1##, so the product is also -1. Where is the flaw in this logic?
Mark44 said:
I am not seeing it.
No flaw. The product is constantly ##-1##, so ##1+(-1)=0##.
Mark44 said:
I am not seeing it.
No flaw in that, but you seemed to be saying it was zero, not -1.
Doh! I got the hard part right, but fouled up on 1 + -1.:H
I tried simplifying and ended up with zero :biggrin: So the series converges and the sum equal to ##0##, correct?
Yes, you can add as many zeroes as you want, you won't get very far. Formally an induction would do, in case anyone comes up with a nonsense like ##\infty \cdot 0##.
I think ##\infty \cdot 0## is interesting :smile:
Thank very much for your help @fresh_42, @Mark44 and @Orodruin
