Is Time Truly Relative in Physics?
  • Context: Graduate
  • Thread starter Thread starter bleachigo
    Relative Time
The discussion revolves around the concept of time relativity in physics, particularly focusing on the implications of time dilation as described by special relativity. Participants explore various interpretations of how time behaves for objects moving at significant fractions of the speed of light, including the mechanics of atomic clocks in motion.
  • One participant proposes that as an object's speed approaches the speed of light, time experienced by that object slows down, suggesting a formula for this effect.
  • Another participant challenges the proposed formula, stating that the correct time dilation factor is the square root of (1 - v²/c²) rather than a linear relationship.
  • A participant questions the isotropy of the proposed model, arguing that if molecular movement affects time perception, it should not be isotropic, and this could lead to inconsistencies in how clocks function at high speeds.
  • Further discussion includes the non-linear nature of time dilation, with participants expressing varying levels of willingness to engage with more complex material on the topic.
  • Several participants express interest in reading materials that could help deepen their understanding of the subject, with suggestions for introductory texts being provided.
There is no consensus on the initial proposal regarding time dilation, as participants present competing views on the correctness of the formula and the implications of isotropy. The discussion remains unresolved regarding the validity of the initial claims and the nature of time dilation.
Participants express varying levels of background knowledge in physics, which influences their engagement with the technical aspects of the discussion. Some acknowledge limitations in their understanding and seek simpler explanations or summaries of complex topics.
This discussion may be of interest to students considering a major in physics, individuals curious about the implications of special relativity, and those seeking to understand the nuances of time dilation and its mathematical representation.
bleachigo
I was sitting in my bed thinking about how time can be relative after i heard about those experiments with atomic clocks slowing down on moving objects. My idea is:
Since it is meant to be impossible to go faster then the speed of light, then as something moves faster, it should become progressively harder to continue speeding up as you get closer and closer to the speed of light.
So if you put a clock, or a person on a train that is moving at half the speed of light. then it means all the molecules of the clock are already moving at half the speed of light, and so any other movement (such as the all the inner workings of the clocks molecules) , would necessarily have to slow down meaning the time measured by the clock or object would slow down proportionally to its velocity relative to the speed of light.
So the equation for the rate that an object experiences time would be something like:
rate of time experienced by object = (c - v) / c where c = speed of light and v = velocity of object.
So as v increases, your experience of time decreases. If v = speed of light then c-v/c = 0 so the object moving at the speed of light wouldn't experience time at all.
Can anyone who knows more about physics confirm if any of this actually makes sense please and tell me what to look up if its been written about before or if its just plain wrong lol.
Well, I'll give you points for a cute, original explanation. Unfortunately, it doesn't work.
First, a technical point: you conclude (c-v)/c as a time dilation factor. This can be written (1 - v/c). The correct factor is sqrt(1- v^2/c^2).
A bigger issue is that your idea is not isotropic. You might be able to rig it to explain 'resistance' to motion in the same direction as the overall motion, but why would that affect motion opposite or perpendicular? So a clock mechanism would behave in a non-isotropic way. That doesn't happen.
If you tell us a little about your background and interest level, people here can readily suggest appropriate books to learn more.
i guess in response to the isotropic movement you could stay, I think it would still be fair to assume that the molecules would still be moving slower even if they are moving in the opposite direction (decelerating) and yes then it is not perfectly isotropic but because the differences are so small it would be negligible since in that case you could say that for all objects there will be molecules moving in different directions and so nothing is isotropic anyway.
If all other movement in the object is slowed down as its velocity is sped up, then any factor that would cause some of the molecules to move in the reverse direction would then also have to be slowed down by a proportional rate. So therefore molecules that are decelerating should be deceleration at a reduced rate relative to if they had done the same thing in a stationary object. Such as if someone drove a car backwards down a train moving near the speed of light, eg if its a car that can accelerate at 40mph per second on earth. To a stationary outsider, it would take longer then 1 second for the car to be moving 40mph less then the train.
if you are going to say that in something as small as a clock, it is not isotropic because some parts will be moving in different directions, I don't see how that is any different from a stationary clock. Since even in a stationary clock there are molecules moving at different speeds and so by the same logic that clock wouldn't be isotropic either. But because the differences are so small they are negligible.
I don't have much of a background in further education in physics other then at A level. So my interest level wouldn't be enough to read an entire book on the subject, something like a summary of paper that could explain it in less then a page or two would be the ideal thing I am looking for.
ps, why would the time dilation factor be squared. Is the rate that time slows down as objects move faster non linear?
Very non-linear.
It will be very hard to try to explain all this to you if you are not willing to read more than a page or two.
PAllen said:
Very non-linear.
I might be willing to read a decent amount just not a book if you get what i mean lol.
Go ahead and suggest some reading material; this is incredibly interesting.
I am currently considering physics as my major. I've had up through Calculus III, Diff. Eq., Matrix Algebra, Abstract Mathematics, and a little bit of Tensor Calculus. Any reading suggestions would be greatly appreciated. Thanks.
Taylor and Wheeler, Spacetime Physics, is the one most people recommend as a reliable first book for a physics student.
Mermin, Space and Time in Special Relativity, is supposed to be another good one.
(I haven't read either of these; I have very old books that I would not recommend as starting points).
  • · Replies 23 ·
  • · Replies 33 ·
  • · Replies 51 ·
