MexChemE
- 237
- 54
Consider an ideal gas with C_V=6.76 \frac{cal}{mol \cdot K}. Calculate \Delta H and \Delta U when ten moles of this gas are heated from 273.15 K to 373.15 K.
\Delta H = \Delta U + P\Delta V
Q=n C_V \Delta T
As I'm given the heat capacity at constant volume I'm assuming this is an isochoric process. That means W=0. Therefore, \Delta U=Q.
\Delta U=Q= (10 \ mol) \left(6.76 \frac{cal}{mol \cdot K} \right) (100 \ K) = 6760 \ cal
Now, for the change in enthalpy we have:
\Delta H = 6760 \ cal + P\Delta V
This is where I'm having trouble. Should I cancel the second term in the above equation? And so have: \Delta H=\Delta U. But, if the gas is heated at constant volume pressure should increase, that means I should consider the PV term in the last equation. I wasn't provided with initial or final values for pressure and volume, so there's not enough information to use PV=nRT. What should I do?
