Isolating a variable gives me endless loop
  • Thread starter Thread starter HKragh
    Loop Variable
The discussion centers around a user experiencing an endless loop while attempting to isolate a variable in a quadratic equation related to a game development project. The equation in question, a = b - ((c*d)/a), leads to confusion when the user multiplies and then divides by "a," effectively undoing their work. Participants clarify that the equation can be rewritten in the standard quadratic form, allowing the use of the quadratic formula to find solutions for "a." The user acknowledges the need to refresh their understanding of these mathematical concepts, highlighting the common struggle of forgetting skills over time. The conversation emphasizes the importance of recognizing inverse operations to avoid similar pitfalls in problem-solving.
HKragh
Coming in here with the following question, when I see what kind of stuff you normally tackle, is very embarrassing! But... I simply am too rusty for this stuff, it seems. This is NOT homework. This is something I need to do in a game I'm working on.
I end up in and endless loop when trying to isolate a variable of an equation. And I have no idea what approach to use to get out of it.
After lots of moving around in the original equation, I end up with this. Which is correct, if I plot in some values. But I need to have a completely isolated.
a=b-((c*d)/a)
Then I try to multiply by "a" on all
a^2 = b*a-c*d
So Now I need to divide by "a"
a = b-((c*d)/a)
Aaand. I'm back.
Please help me out with what seems to be VERY easy, if you know your stuff.
Mathematics news on Phys.org
One of my colleagues helped me out. This is, as you probably already know, a second degree polynomial. So just to make sure the solution is in here, even though none of you probably care:
The variable names are based on the equation above, and so the placement of each might seem out of place with the standard look of it.
D=b^2-4cd
a = (-b+-sqrt(D))/-2
D>0 : 2 solutions
D=0 : 1 solution
D<0 : 0 solutions
Yes, by identifying the equation as a quadratic polynomial then you know to use the quadratic formula:
http://en.wikipedia.org/wiki/Quadratic_formula
Its good you answered you own question and posted it as well.
So once you have the equation as a^2 = b*a-c*d and rewrite it as: a^2 - ba + cd = 0
then you can see it matches the Ax^2 + Bx + C = 0 format where in your case x=a, A = 1, B=b, C=cd
and the roots for x are (ie your a) are: x = -B/2A +- sqrt(B^2 - 4AC) / 2A
a = -b/2 +- sqrt(b^2 - 4cd)
thx for the extra info, jedishrfu! At some point in life (technical high school thingy) I knew more about this stuff, and solved many problems like this. Then time went by, and I forgot it all. I must say yesterdays experience has made it clear I need to rediscover this set of skills! It must be buried in there, somewhere... :)
The things we learn last are the things we forget first. I know the feeling.
Your "endless loop" came, of course, from your "multiplying by a" in the first step and them "dividing by a" in the second step! Multiplication and division are inverse operations so, in the second step, you just "undid" what you did in the first step.
I know :) The problem was that the only method I knew at the time to get rid of the "a" was by multiplying by it on all terms. And then I had the "a" still as a multiplication, and only knew division as a method to get rid of that. I very much aware how that got me into the loop. That is why I searched for a completely different method than simply multiplying and dividing my term.
