Isolating a variable in an exponent
  • Thread starter Thread starter thatguythere
    Exponent Variable
15 replies · 4K views
thatguythere
So I had to find out
N=Noe-ux
Where No=1.5,e is the elementary charge, u=-0.068 and x=0.07
I came to the answer 1.221
Now I need to find x if u =-0.036, N=1.221 and No remains 1.5
I reduce the equation to the following
ln(N/No)=-ux
The problem is that when I plug my numbers from the original problem into this I end up getting the following
ln(1.221/1.5)=-(-0.068)x
-0.2058=0.068x
-3.02= x
This is clearly incorrect since I know x should be 0.07.
Any help would be greatly appreciated.
Thank you.
N=Noe-ux
I get something different.
I'll assume u = -0.036 is a typo because it looks as though you want to use u = -0.068 again.
Just check your answer for N again, and see if that changes anything.
My order of operations was wrong then?
So I get 1.273
Now -0.036 was NOT a typo, however I am ignoring it, as I am using the original numbers to try to figure out how to isolate x. However, when I plug this new number in, I still end up with x = -2.413 instead of 0.07 which it should be.
Clearly I am doing something very wrong and have no idea what.
Let me illustrate step by step.
N=Noe-ux
N=1.5*1.6x10-19(0.068)(0.07)
N=1.5*0.0960.07
N=1.5*0.849
N=1.274
Now I try to reverse it to figure out how to isolate x, this is where I do something very wrong I believe.
N=Noe-ux
1.274=1.5*1.6x10-19(0.068)(x)
0.849=1.6x10-19(0.068)(x)
ln0.849=0.068x
-0.164=0.068x
-2.41=x
But we know x=0.07. I'm lost.
So I get 1.273
Sorry, I mistook e as being the natural exponential 2.718...
We're supposed to be using [itex]e=1.602\cdot10^{-19}[/itex], right?
Using the figures:
[tex]N_0 = 1.5[/tex]
[tex]e=1.602\cdot 10^{-19}[/tex]
[tex]u=-0.068[/tex]
[tex]x=0.07[/tex]
You should get [itex]N\approx 1.22[/itex]
N=1.5*0.0960.07
How did you go from the first to the second step?
Haha Ok so I was correct in the first place when I posted 1.221. Then I was trying to figure out what I did wrong which would explain your confusion over my next process.
thatguythere said:
I did 1.6x10-19(0.068)
Is that improper order of operations?
Yes, it's not correct.
[tex](n\cdot a^b)^{cd} = n^{cd}\cdot a^{bcd}[/tex]
But you've done something else.
Of course, calculating them in this way is the long and inefficient way, so you'd instead enter it as so:
(1.6E-19)^(0.068*0.07)
EDIT: most of this is redundant, you already know it :smile:
Oh yeah sorry, that's my fault!
As for the second part of the problem where you're trying to find x, you've done essentially what confused me as well.
ln(N/No)=-ux
Remember that ln = loge is the natural logarithm, or in other words, it reverses the natural exponential operator.
If [itex]a=e^{b}[/itex] then [itex]\ln(a)=b[/itex] but we don't have the natural exponential (e=2.718...) here, we have another base altogether, so what we'd need to do to reverse the exponent operation is to take the log with base [itex]1.6\cdot 10^{-19}[/itex]
But your calculator probably doesn't have the option of choosing any base for the logarithm, so you instead use the formula
[tex]\log_ab=\frac{\log_cb}{\log_ca}[/tex]
So we have that
[tex]\log_{1.6\cdot 10^{-19}}(1.221/1.5) = \frac{\ln (1.221/1.5)}{\ln(1.6\cdot 10^{-19})}[/tex]
Are you saying that
[itex]\frac{ln(1.221/1.5)}{ln(1.6E-19)}[/itex]=-ux?
Yeah, I got that. So using -0.036, I come up with 0.132. Excellent.
Thank you very much.
You're welcome! And sorry about the confusion at the start.
