Isothermal Process Homework: Calculate Q(in) & Q(out)
  • Thread starter Thread starter aznmaverick
    Isothermal Process
The discussion revolves around calculating Q(in) and Q(out) for an isothermal process involving a gas transitioning from state C to A. The specific heat is given as Cv = 5/2 R, with R defined as 8.314 J/mol K. The main challenge is determining the temperature (T) needed to solve for the work done (W) using the equation W = nRT ln(Va/Vc). Participants clarify that while n is known to be 1 mole, T remains unknown, leading to the conclusion that a definitive answer cannot be reached without additional information about T. The ideal gas law is emphasized as a crucial connection between the variables in this context.
aznmaverick
Calculate Q(in) and Q(out).
Specific Heat: Cv = 5/2 R
R = 8.314 J/mol K
For the process C-> A, it is an isothermic process but we are not given temperature. The equation to finding the total work done from C->A is nRT ln (Va/Vc). How do I get T in order to solve for nRT ln (Va/Vc)?
Hint: is there a constitutive equation for this substance?
Yes, I got that from Q (from C to A) = Delta U (C to A) + W (C to A) and since Delta U (C to A) = 0, Q (C to A) = W ( C to A).
W (C to A) for an isothermal process is = (Integral from C to A) P dv
Using the formula PV = nRT and solving for P, we get P = nrT/V, so W (C to A) = (Integral from C to A) nRT/V dv, which comes out to be nRT ln v (from C to A). Finally plugging in C and A, we get nRT ln (Va - Vc) = nRT ln (Va/Vc)
The value of nRT can be easily calculated even though neither n nor T are known. Know what I mean?
Yes, well, n=1 mole, and T is unknown, but we know that its a constant. So we cannot solve for it?
How do you know that there's one mole present? Is there more information in the problem statement that you didn't post?
In any case, the ideal gas law connects all these variables together.
Yea, 1 mole was a given. T is still not given. So does that mean there's no 'real answer' to this question w/o T given?
If P, V, and n are known for an ideal gas, then T is known.
Got it, thanks!
10K
