Java - bag adt with linked list
  • Context: Comp Sci
  • Thread starter Thread starter schapman22
    Java List
2 replies · 6K views
schapman22
"Implement a new method for the bag class. The new method allows you to subtract the contents of one bag from another. For example, suppose x has seven copies of the number 3 and y has two copies of the number 3. Then after activating x.subtract(y), the bag x will have five remaining copies of the number 3. "
This is the bag class, it is implemented with a linked list. It uses another class called IntNode, the methods from this class can be used as well so i add both classes.
Code:
// File: IntLinkedBag.java from the package edu.colorado.linked
// Complete documentation is available from the IntLinkedBag link in:
//   http://www.cs.colorado.edu/~main/docs
package edu.colorado.collections;
import edu.colorado.nodes.IntNode;
* An IntLinkedBag is a collection of int numbers.
* @note
*   (1) Beyond Int.MAX_VALUE elements, countOccurrences,
*   size, and grab are wrong.
*   <p>
*   (2) Because of the slow linear algorithms of this class, large bags will have
*   poor performance.
* @see
*   <A HREF="../../../../edu/colorado/collections/IntLinkedBag.java">
*   Java Source Code for this class
*   (www.cs.colorado.edu/~main/edu/colorado/collections/IntLinkedBag.java)
*   </A>
* @author Michael Main
*   <A HREF="mailto:main@colorado.edu"> (main@colorado.edu) </A>
* @version
*   March 6, 2002
* @see IntArrayBag
* @see LinkedBag
public class IntLinkedBag implements Cloneable
   // Invariant of the IntLinkedBag class:
   //   1. The elements in the bag are stored on a linked list.
   //   2. The head reference of the list is in the instance variable
   //      head.
   //   3. The total number of elements in the list is in the instance
   //      variable manyNodes.
   private IntNode head;
   private int manyNodes;
   * Initialize an empty bag.
   * @param - none
   * @postcondition
   *   This bag is empty.
   public IntLinkedBag( )
      head = null;
      manyNodes = 0;
   * Add a new element to this bag.
   * @param element
   *   the new element that is being added
   * @postcondition
   *   A new copy of the element has been added to this bag.
   * @exception OutOfMemoryError
   *   Indicates insufficient memory a new IntNode.
   public void add(int element)
      head = new IntNode(element, head);
      manyNodes++;
   * Add the contents of another bag to this bag.
   * @param addend
   *   a bag whose contents will be added to this bag
   * @precondition
   *   The parameter, addend, is not null.
   * @postcondition
   *   The elements from addend have been added to this bag.
   * @exception NullPointerException
   *   Indicates that addend is null.
   *   Indicates insufficient memory to increase the size of the bag.
   public void addAll(IntLinkedBag addend)
      IntNode[ ] copyInfo;
      // The precondition indicates that addend is not null. If it is null,
      // then a NullPointerException is thrown here.
      if (addend.manyNodes > 0)
         copyInfo = IntNode.listCopyWithTail(addend.head);
         copyInfo[1].setLink(head); // Link the tail of copy to my own head...
         head = copyInfo[0];        // and set my own head to the head of the copy.
         manyNodes += addend.manyNodes;
   * Add new elements to this bag. If the new elements would take this
   * bag beyond its current capacity, then the capacity is increased
   * before adding the new elements.
   * @param elements
   *   (a variable-arity argument)
   *   one or more new elements that are being inserted
   * @postcondition
   public void addMany(int... elements)
      // Activate the ordinary add method for each integer in the
      // elements array.
      for (int i : elements)
          add(i);
   * Generate a copy of this bag.
   * @param - none
   * @return
   *   The return value is a copy of this bag. Subsequent changes to the
   *   copy will not affect the original, nor vice versa. Note that the return
   *   value must be type cast to an IntLinkedBag before it can be used.
   *   Indicates insufficient memory for creating the clone.
   public Object clone( )
   {  // Clone a nIntLinkedBag object.
      IntLinkedBag answer;
      try
         answer = (IntLinkedBag) super.clone( );
      catch (CloneNotSupportedException e)
      {  // This exception should not occur. But if it does, it would probably
         // indicate a programming error that made super.clone unavailable.
         // The most common error would be forgetting the "Implements Cloneable"
         // clause at the start of this class.
         throw new RuntimeException
         ("This class does not implement Cloneable");
      answer.head = IntNode.listCopy(head);
      return answer;
   * Accessor method to count the number of occurrences of a particular element
   * in this bag.
   * @param target
   *   the element that needs to be counted
   * @return
   *   the number of times that target occurs in this bag
   public int countOccurrences(int target)
      int answer;
      IntNode cursor;
      answer = 0;
      cursor = IntNode.listSearch(head, target);
      while (cursor != null)
      {  // Each time that cursor is not null, we have another occurrence of
         // target, so we add one to answer and then move cursor to the next
         // occurrence of the target.
         answer++;
         cursor = cursor.getLink( );
         cursor = IntNode.listSearch(cursor, target);
      return answer;
   * Accessor method to retrieve a random element from this bag.
   * @param - none
   * @precondition
   *   This bag is not empty.
   * @return
   *   a randomly selected element from this bag
   * @exception IllegalStateException
   *   Indicates that the bag is empty.
   public int grab( )
      int i;
      IntNode cursor;
      if (manyNodes == 0)
         throw new IllegalStateException("Bag size is zero");
      i =  (int)(Math.random( ) * manyNodes) + 1;
      cursor = IntNode.listPosition(head, i);
      return cursor.getData( );
   * Remove one copy of a specified element from this bag.
   * @param target
   *   the element to remove from the bag
   * @postcondition
   *   If target was found in the bag, then one copy of
   *   target has been removed and the method returns true.
   *   Otherwise the bag remains unchanged and the method returns false.
   public boolean remove(int target)
      IntNode targetNode; // The node that contains the target
      targetNode = IntNode.listSearch(head, target);
      if (targetNode == null)
         // The target was not found, so nothing is removed.
         return false;
      else
      {  // The target was found at targetNode. So copy the head data to targetNode
         // and then remove the extra copy of the head data.
         targetNode.setData(head.getData( ));
         head = head.getLink( );
         manyNodes--;
         return true;
   * Determine the number of elements in this bag.
   * @param - none
   * @return
   *   the number of elements in this bag
   public int size( )
      return manyNodes;
   * Create a new bag that contains all the elements from two other bags.
   * @param b1
   *   the first of two bags
   * @param b2
   *   the second of two bags
   * @precondition
   *   Neither b1 nor b2 is null.
   * @return
   *   the union of b1 and b2
   * @exception IllegalArgumentException
   *   Indicates that one of the arguments is null.
   *   Indicates insufficient memory for the new bag.
   public static IntLinkedBag union(IntLinkedBag b1, IntLinkedBag b2)
      // The precondition requires that neither b1 nor b2 is null.
      // If one of them is null, then addAll will throw a NullPointerException.
      IntLinkedBag answer = new IntLinkedBag( );
      answer.addAll(b1);
      answer.addAll(b2);
      return answer;
   public void getBagData()
       IntNode b1 = this.head;
       for(IntNode cursor=b1; cursor!=null; cursor=cursor.getLink())
           System.out.println(cursor.getData());
this is my incomplete attempt.
Code:
public IntLinkedBag subtract(IntLinkedBag b2)
       IntNode bag1 = this.head;
       IntNode bag2 = b2.head;
       for(IntNode cursor=bag1; cursor!=null; cursor=cursor.getLink())
           //remove if same as bag2
       return this;
This is the IntNode class that is used.
Code:
// File: IntNode.java from the package edu.colorado.nodes
// Complete documentation is available from the IntNode link in:
package edu.colorado.nodes;
* An IntNode provides a node for a linked list with
* integer data in each node.
* @note
*   Lists of nodes can be made of any length, limited only by the amount of
*   free memory in the heap. But beyond Integer.MAX_VALUE (2,147,483,647),
*   the answer from listLength is incorrect because of arithmetic
*   overflow.
* @see
*   <A HREF="../../../../edu/colorado/nodes/IntNode.java">
*   (www.cs.colorado.edu/~main/edu/colorado/nodes/IntNode.java)</A>
* @version
*   March 6, 2002
* @see Node
* @see BooleanNode
* @see ByteNode
* @see CharNode
* @see DoubleNode
* @see FloatNode
* @see LongNode
* @see ShortNode
public class IntNode
   // Invariant of the IntNode class:
   //   1. The node's integer data is in the instance variable data.
   //   2. For the final node of a list, the link part is null.
   //      Otherwise, the link part is a reference to the
   //      next node of the list.
   private int data;
   private IntNode link;
   * Initialize a node with a specified initial data and link to the next
   * node. Note that the initialLink may be the null reference,
   * which indicates that the new node has nothing after it.
   * @param initialData
   *   the initial data of this new node
   * @param initialLink
   *   a reference to the node after this new node--this reference may be null
   *   to indicate that there is no node after this new node.
   * @postcondition
   *   This node contains the specified data and link to the next node.
   public IntNode(int initialData, IntNode initialLink)
      data = initialData;
      link = initialLink;
   * Modification method to add a new node after this node.
   * @param item
   *   the data to place in the new node
   * @postcondition
   *   A new node has been created and placed after this node.
   *   The data for the new node is item. Any other nodes
   *   that used to be after this node are now after the new node.
   *   Indicates that there is insufficient memory for a new
   *   IntNode.
   public void addNodeAfter(int item)
      link = new IntNode(item, link);
   * Accessor method to get the data from this node.
   * @param - none
   * @return
   *   the data from this node
   public int getData( )
      return data;
   * Accessor method to get a reference to the next node after this node.
   * @param - none
   * @return
   *   a reference to the node after this node (or the null reference if there
   *   is nothing after this node)
   public IntNode getLink( )
      return link;
   * Copy a list.
   * @param source
   *   the head of a linked list that will be copied (which may be
   *   an empty list in where source is null)
   * @return
   *   The method has made a copy of the linked list starting at
   *   source. The return value is the head reference for the
   *   copy.
   *   Indicates that there is insufficient memory for the new list.
   public static IntNode listCopy(IntNode source)
      IntNode copyHead;
      IntNode copyTail;
      // Handle the special case of the empty list.
      if (source == null)
         return null;
      // Make the first node for the newly created list.
      copyHead = new IntNode(source.data, null);
      copyTail = copyHead;
      // Make the rest of the nodes for the newly created list.
      while (source.link != null)
         source = source.link;
         copyTail.addNodeAfter(source.data);
         copyTail = copyTail.link;
      // Return the head reference for the new list.
      return copyHead;
   * Copy a list, returning both a head and tail reference for the copy.
   * @param source
   * @return
   *   source.  The return value is an
   *   array where the [0] element is a head reference for the copy and the [1]
   *   element is a tail reference for the copy.
   public static IntNode[ ] listCopyWithTail(IntNode source)
      IntNode copyHead;
      IntNode copyTail;
      IntNode[ ] answer = new IntNode[2];
      if (source == null)
         return answer; // The answer has two null references .
      // Return the head and tail references.
      answer[0] = copyHead;
      answer[1] = copyTail;
      return answer;
   * Compute the number of nodes in a linked list.
   * @param head
   *   the head reference for a linked list (which may be an empty list
   *   with a null head)
   * @return
   *   the number of nodes in the list with the given head
   * @note
   *   A wrong answer occurs for lists longer than Int.MAX_VALUE.
   public static int listLength(IntNode head)
      IntNode cursor;
      int answer;
      answer = 0;
      for (cursor = head; cursor != null; cursor = cursor.link)
         answer++;
      return answer;
   * Copy part of a list, providing a head and tail reference for the new copy.
   * @param start/end
   *   references to two nodes of a linked list
   * @param copyHead/copyTail
   *   the method sets these to refer to the head and tail node of the new
   *   list that is created
   * @precondition
   *   start and end are non-null references to nodes
   *   on the same linked list,
   *   with the start node at or before the end node.
   * @return
   *   The method has made a copy of the part of a linked list, from the
   *   specified start node to the specified end node. The return value is an
   *   array where the [0] component is a head reference for the copy and the
   *   [1] component is a tail reference for the copy.
   *   Indicates that start and end are not references
   *   to nodes on the same list.
   *   Indicates that start is null.
   public static IntNode[ ] listPart(IntNode start, IntNode end)
      IntNode copyHead;
      IntNode copyTail;
      IntNode cursor;
      // Make the first node for the newly created list. Notice that this will
      // cause a NullPointerException if start is null.
      copyHead = new IntNode(start.data, null);
      cursor = start;
      while (cursor != end)
         cursor = cursor.link;
         if (cursor == null)
            throw new IllegalArgumentException
            ("end node was not found on the list");
         copyTail.addNodeAfter(cursor.data);
      return answer;
   * Find a node at a specified position in a linked list.
   * @param head
   *   the head reference for a linked list (which may be an empty list in
   *   which case the head is null)
   * @param position
   *   a node number
   * @precondition
   *   position > 0.
   * @return
   *   The return value is a reference to the node at the specified position in
   *   the list. (The head node is position 1, the next node is position 2, and
   *   so on.) If there is no such position (because the list is too short),
   *   then the null reference is returned.
   *   Indicates that position is not positive.
   public static IntNode listPosition(IntNode head, int position)
      IntNode cursor;
      int i;
      if (position <= 0)
           throw new IllegalArgumentException("position is not positive");
      cursor = head;
      for (i = 1; (i < position) && (cursor != null); i++)
      return cursor;
   * Search for a particular piece of data in a linked list.
   * @param head
   * @param target
   *   a piece of data to search for
   * @return
   *   The return value is a reference to the first node that contains the
   *   specified target. If there is no such node, the null reference is
   *   returned.
   public static IntNode listSearch(IntNode head, int target)
      IntNode cursor;
         if (target == cursor.data)
            return cursor;
      return null;
   * Modification method to remove the node after this node.
   * @param - none
   * @precondition
   *   This node must not be the tail node of the list.
   * @postcondition
   *   The node after this node has been removed from the linked list.
   *   If there were further nodes after that one, they are still
   *   present on the list.
   *   Indicates that this was the tail node of the list, so there is nothing
   *   after it to remove.
   public void removeNodeAfter( )
      link = link.link;
   * Modification method to set the data in this node.
   * @param newData
   *   the new data to place in this node
   * @postcondition
   *   The data of this node has been set to newData.
   public void setData(int newData)
      data = newData;
   * Modification method to set the link to the next node after this node.
   * @param newLink
   *   a reference to the node that should appear after this node in the linked
   *   list (or the null reference if there is no node after this node)
   * @postcondition
   *   The link to the node after this node has been set to newLink.
   *   Any other node (that used to be in this link) is no longer connected to
   *   this node.
   public void setLink(IntNode newLink)
      link = newLink;
   public void printRange(IntNode head, int x, int y)
       for (IntNode cursor = head; cursor!=null; cursor = cursor.link)
           if(cursor.data>=x && cursor.data<=y)
               System.out.println(cursor.data);
   public static IntNode removeDuplicates(IntNode h)
       IntNode copyHead = new IntNode (h.data, null);
       IntNode cursor2 = copyHead;
       for(IntNode cursor=h.link;cursor!=null; cursor=cursor.link)
           if(!(IntNode.listSearch2(copyHead,cursor.data)))
              cursor2.addNodeAfter(cursor.data);
              cursor2 = cursor2.link;
       return copyHead;
   public static boolean listSearch2(IntNode head, int target)
      IntNode cursor;
            return true;
      return false;
    public static IntNode reverseList(IntNode head)
        int i;
        int length = IntNode.listLength(head);
        IntNode copyHead, cursor;
        IntNode copyTail = IntNode.listPosition(head, length);
        copyHead = new IntNode(copyTail.data, null);
        cursor = copyHead;
        for (i = length - 1; i >= 1; i--)
            copyTail = IntNode.listPosition(head, i);
            cursor.addNodeAfter(copyTail.data);
            cursor = cursor.getLink();
        return copyHead;
   public static IntNode listSort(IntNode head)
        IntNode cursor;
        int largest;
        IntNode copyHead=null;
        IntNode target;
        while(head!=null)
            target = head;
            largest = head.data;
            for(cursor=head.link;cursor!=null;cursor=cursor.link)
                if(cursor.data > largest)
                    target=cursor;
                    largest=cursor.data;
            copyHead = new IntNode(target.data, copyHead);
            target.setData(head.data);
            head=head.link;
        return copyHead;
I think I got it working properly, let me know if you find any bugs.
Code:
       IntNode cursor;
            for(cursor=bag2; cursor!=null; cursor=cursor.getLink())
                if(bag1.getData()==cursor.getData())
                    this.remove(bag1.getData());
                bag1=bag1.getLink();
       return this;
