Java Method for Replacing String in a Text
  • Context: Java
  • Thread starter Thread starter JaysFan31
    Method
5 replies · 4K views
JaysFan31
Hi. I just need some help tweaking a program I'm working on for a class. I just started taking Java a few weeks ago, so I need to use elementary language.
Basically, I have to create a method that does what it says in the comment (replace each occurrence of the second string in the first string with the third string).
The first two loops work (if and else if) obviously work fine. I just need help with the third one (when the lengthFind < lengthOriginal). The code makes sense to me and it compiles. However, I get all kinds of "index out of range" problems. I have no idea how to fix these and because of that I can't check my code anyways.
With something like ("She sells seashells by the sea shore", "sh", "shm"), I should return "She sells seashmells by the sea shmore".
Any help, advice, or tiny tweaks to the code would be appreciated. I'm pretty much out of ideas at this point.
Code:
// (c) method called replaceString
 // method looks for occurrences of second string in first string
 // method replaces each occurrence of second string in first string with third string
public static String replaceString(String original, String find, String replacement)
  int lengthOriginal = original.length();
  int lengthFind = find.length();
  int lengthReplacement = replacement.length();
  String finalString = "";
  String mutation = "";
  if (lengthFind > lengthOriginal)
    finalString = original;
  else if (lengthFind == lengthOriginal)
    if (find.equals(original))
    finalString = replacement;
    else
  else
    for (int i = 0; i <= lengthOriginal; i++)
      String partBefore;
      String partAfter;
      char characterOriginal = original.charAt(i);
      char characterFind = find.charAt(0);
      mutation = original.substring(i, i + lengthFind);
      if (mutation.equals(find))
        partBefore = original.substring(0, i);
        partAfter = original.substring(i + lengthFind);
        finalString = partBefore + replacement + partAfter;
  return finalString;
This is my revised code:
*Note* I'm just including the last section (the else statement similar to the code in my first post):
Code:
else
	for (int i = 0; i <= (lengthOriginal - lengthFind); i++)
	  String partBefore;
	  String partAfter;
		original = partBefore.concat(replacement);
		original = original.concat(partAfter);
		System.out.println(original);
It works perfectly if LengthFind <= LengthReplacement. I just can't get it to work when lengthReplacement is larger than the LengthFind. It does everything correctly. It compiles and I even included the System.out.println(original); to see what the string looks like at that step (it's correct there.) However, it prints like ten lines of "index out of range" errors still. Obviously, it's working. I just can't get it to work without these errors. Can anyone help me?
Again, I want to input something like ("She sells seashells", "he", "h") and output "Sh sells seashlls".
If you change the length of the string "original", then your variable "lengthOriginal" is no longer the length of the string.
Also, when you find a match, you might want to think about adjusting "i" as well. For example if you replaced ab with aa, this might happen:
abbbxx becomes aabbxx
then
aabbxx becomes aaabxx
then
aaabxx becomes aaaaxx
which might not be what you wanted.
Thank you so much. It was as simple as changing "lengthOriginal" and just making it "original.length()."
Again I really appreciate it.
You should use Java docs and the standard library. The Java Way:
Code:
	 * Replaces each occurrence of the find string in original string with
	 * replacement string
	 * @param original
	 * @param find
	 * @param replacement
	 * @return replaced string.
			String replacement) {
		return original.replaceAll(find, replacement);
If nothing else try to use JavaDocs for comments.
Code:
	 * @param original
	 * @param find
Somehow I get the feeling he won't get very many marks for that solution.
