marcus
Homework Helper
Dearly Missed
- 24,752
- 795
I imagine that by now most people who might read this thread have figured out why the 4D block universe of General Relativity is incompatible with quantum uncertainty. The incompatibility is across the board---all common mainstream interpretations/formulations of QM for which uncertainty is an underlying bedrock principle. So perhaps I don't have to provide explanation (beyond what we already have in the quotes from George Ellis. But here's an excerpt from an essay by Carlo Rovelli that explains the point very clearly. This from page 4 of Chapter 1 of the 2009 book Approaches to Quantum Gravity, D. Oriti ed. published by Cambridge University Press ( http://arxiv.org/abs/gr-qc/0604045 )
==quote Chapter 1 of Approaches to Quantum Gravity==
In classical GR, indeed, the notion of time differs strongly from the one used in the special-relativistic context. Before special relativity, one assumed that there is a universal physical variable t, measured by clocks, such that all physical phenomena can be described in terms of evolution equations in the independent variable t. In special relativity, this notion of time is weakened. Clocks do not measure a universal time variable, but only the proper time elapsed along inertial trajectories. If we fix a Lorentz frame, nevertheless, we can still describe all physical phenomena in terms of evolution equations in the independent variable x0, even though this description hides the covariance of the system.
In general relativity, when we describe the dynamics of the gravitational field (not to be confused with the dynamics of matter in a given gravitational field), there is no external time variable that can play the role of observable independent evolution variable. The field equations are written in terms of an evolution parameter, which is the time coordinate x0, but this coordinate, does not correspond to anything directly observable. The proper time τ along spacetime trajectories cannot be used as an independent variable either, as τ is a complicated non-local function of the gravitational field itself. Therefore, properly speaking, GR does not admit a description as a system evolving in terms of an observable time variable. This does not mean that GR lacks predictivity. Simply put, what GR predicts are relations between (partial) observables, which in general cannot be represented as the evolution of dependent variables on a preferred independent time variable.
This weakening of the notion of time in classical GR is rarely emphasized: After all, in classical GR we may disregard the full dynamical structure of the theory and consider only individual solutions of its equations of motion. A single solution of the GR equations of motion determines “a spacetime”, where a notion of proper time is associated to each timelike worldline.
But in the quantum context a single solution of the dynamical equation is like a single “trajectory” of a quantum particle: in quantum theory there are no physical individual trajectories: there are only transition probabilities between observable eigenvalues. Therefore in quantum gravity it is likely to be impossible to describe the world in terms of a spacetime, in the same sense in which the motion of a quantum electron cannot be described in terms of a single trajectory.
==endquote==
Having a block universe with some definite course of geometry would be like a trajectory.
A trajectory is a classical idea, it is not physical. We do not have continuous smooth trajectories, we have slits and detectors
that is to say a finite number of measurements made along the way.
There are an infinite number of possible observations/measurements of the path of a particle or geometry of the universe. But nature does not let herself be pinned down, we can only choose a finite number of them to make. Moreover each measurement may have a range of possible values and involve uncertainty.
I suspect this is why the smooth manifold--the continuum model of the physical world including space-time--is apt to be replaced by something more like an algebra of observables, each one a package of uncertainty with its range of possible values. We see this replacement model being tentatively tried out by researchers. Time is then no pseudo-spatial "dimension" but a flow defined on the algebra.
==endquote==
