What is the actual size of a photon?
  • Context: Graduate
  • Thread starter Thread starter Neo_Anderson
    Photon
The discussion centers on the size of a photon, concluding that photons are point particles in quantum mechanics (QM) with no spatial extension. Participants debate the relevance of the Schwarzschild radius and the classical electron radius in defining the limits of size for massless particles like photons. The natural size of a photon is suggested to be related to its wavelength, approximately λ, and the conversation highlights the complexities of measuring size in quantum contexts. Key concepts include the relationship between energy and mass, as well as the implications of black hole physics on particle size.
  • Quantum Mechanics (QM) principles
  • Schwarzschild radius and its implications
  • Classical electron radius
  • Mass-energy equivalence (E=mc²)
  • Research the implications of the Schwarzschild radius on massless particles
  • Explore the concept of point particles in Quantum Mechanics
  • Study the relationship between wavelength and photon size
  • Investigate the role of black holes in particle physics
Physicists, students of quantum mechanics, and anyone interested in the fundamental properties of light and particles.
Neo_Anderson
A high-energy photon needs a smaller aperture to get down to its limit of resolution. Conversely, a radio wave needs an enormous aperture if it is to go through it (an RF waveguide, eg, is like 3"x7").
So what exactly is the size of the photon? Since they're created in atoms, I'd think they're about the size of an atom, maybe smaller. Interesting, since an atom can generate an RF wave that can't even fit in something smaller than a waveguide, whereas another atom can generate a photon that has no problem entering a 600 nm aperture...
A ridiculous question, I know, but valid nonetheless.
How large is a wave on the pond?
Photons are pointparticles in QM, they have no spatial extension, just as electrons, quarks and force carrier bosons.
Schwarzschild radius?
mass = 0...
ansgar said:
mass = 0...
Energy != 0.
dmtr said:
Energy != 0.
scharchild radius is not related to "physical" radius (whatever that is...)
How comes? Schwarzschild radius is a real radius in the real space.
Can you explain to me what the Schwarzschild radius is? The Earth has a radius different than it's density distribution radius (which is what we commonly call "size")
Er.. http://en.wikipedia.org/wiki/Schwarzschild_radius
For an electron it is a lot smaller compared to the Plank's length. Still, it is better, compared to the point!
The original question was "what exactly is the size of the photon", it can be reformulated - "in how small volume can you 'squeeze' the photon", well, to do that you only need to throw it in the black hole. The resulting volume wouldn't be zero.
I know what it is, but you didn't seem to know it so I asked you to explain it.
One can also use the "Classical electron radius" (http://en.wikipedia.org/wiki/Classical_electron_radius) if one just wants a number, but the figure of interest is the radius for the matter distribution, not "Schwarzschild radius" etc.. and the radius asked for should be understood as the matter radius...
AFAIK Schwarzschild radius sets a fundamental limit of how much mass/energy (information) you can pack in space. And it do set the lower limit on the size of the photon and electron.
Can you say what the smallest size of a photon then, which has zero mass...
In QM, it is a point particle.
All speculations about the plank length, Schwarzschild radius etc require the Quantum Gravity theory which is not ready yet.
that was supposed to be my next move! :D
R_{s} = \frac{2Gh\nu}{c^{4}}
And just for the fun of it:
A = 4\pi{R_{s}}^{2},
S = \frac{c^{3}A}{4 \hbar G} bits
derivation?...
Well, you are right of course. But I see nothing wrong in throwing an electron or a photon into a black hole and considering 'how small can it get there'.
ansgar said:
derivation?...
E = mc^{2} = h\nu
R_{s} = \frac{2Gm}{c^{2}}
That is incorrect.
If someone asks "what is the size of dmtr", we don't start looking for the answer by squeezing dmtr with a hydraulic press.
The natural size of dmtr is the size of the smallest hole through which we can shoot him without significantly distorting the form of his wave packet. It is probably between 1 and 2.5 meters - many orders of magnitude greater than Schwartzschild radius of dmtr.
Similarly, the natural size of a photon with wavelength \lambda is approximately \lambda.
hamster143 said:
That is incorrect.
My protest was to the notion of 'point particles' and the associated infinities. As to the size, I think it is very natural to measure sizes in bits. For example, imagine a photon with a wavelength comparable with the radius of the universe. All you can tell about that photon, is whether it is present, or not. Nothing else. That would be exactly one bit. So very naturally the size of that photon would be one bit. ;)
dmtr said:
E = mc^{2} = h\nu
Does not apply to a photon...
Well, let's just agree that the protest was worse than the notion.
The other problem I have with Schwarzschild radius is that it's just a severely overhyped number. There's nothing magical about Schwarzschild radius. If you're falling into a black hole, you don't "hit the surface", so to speak, at \frac{2Gm}{c^{2}}. You may not even notice that anything has happened. The black hole itself is pointlike (or, rather, has the diameter on the order of Planck length).
hamster143 said:
That is incorrect.
I agree with the "The natural size of a photon is the size of the smallest hole through which we can shoot it". But you don't need to add 'without significantly distorting'. You can either shoot a photon through that hole or not. If the hole radius is smaller than the Schwartzschild radius for that photon, you wouldn't be able to shoot that photon through. It won't fit.
Note that the size of the hole have a units of area, in the natural units it is measured in bits (Plank's area is equal to one bit). As a result the natural size of a photon should be measured in bits. (The smallest photon would be the photon with the largest wavelength [radius of the universe], and AFAIK, if you calculate the size of it, it would come out as one bit ;)
Nah. It doesn't come out as one bit. Not even close. It looks like:
R_{s} = \frac{2 G m}{c^{2}}
E = m c^2 = h \nu = \frac{h c}{\lambda}
A = 4 \pi {R_{s}}^{2}
A_{bit} = \frac{h G}{2 \pi c^{3}}
S_{bits} = \frac{A}{A_{bit}}= \frac{16 \pi^{2} h G c}{\lambda^{2}}
where {\lambda} is the photons wavelength.
Not valid, did you fail your special relativity class? :)
I'm a CS grad :). Why? Is there any other way to calculate the equivalent increase of the mass of the black hole, if you throw a photon into it?
E = mc^2 is not valid for a photon...
E^2 = (mc^2)^2 + (pc)^2
or did you mean that m = m_0 x Gamma ?
then Gamma = infinity for photons...
sorry dmtr, there is something strange going on here :(
and what is a CS grad?
  • · Replies 46 ·
  • · Replies 131 ·
26K
  • · Replies 19 ·
  • · Replies 52 ·
  • · Replies 62 ·
11K
