Kalman filter and simulating Gaussian noise
5 replies · 3K views
Dustinsfl
Water level assumed constant. Static state model \(P_0 = 1000\), system noise \(Q = 0.0001\), measurement noise \(R = 0.1\).
I want to use Kalman filtering to solve this problem. I know how to do this but I need to generate \(\mathbf{y} = y\) using Gaussian random noise. \(P_0\) is also call the variance which is high do to uncertanity in \(x_0\).
How do I generate 10 y values based on Gaussian random noise with these conditions?
These values come from here.
Then I have a copy the same presentation but page 7-9 are additionally hand written pages with more info and everything before and after these pages are identical to the first link.
I found a presentation on the topic by Stanford; unfortunately, I don't see how to apply it to the problem. If someone can help with this, that would be great.
On page 14, they go over linear measurements of the form \(y = Ax + v\).
Stanford lecture
This is just a beamer style presentation so it isn't dense.
The $$y$$'s are $$\sim N(y_{true},R)$$ with $$y_{true}=1$$ and $$R=1/10$$, so in Matlab code a sample of 10 $$y$$'s would be generated thusly:
Code:
--> ysamp=1+randn(1,10)/sqrt(10)
ysamp =
 Columns 1 to 6
    1.0032    1.0506    0.5366    0.9875    1.3739    0.7645
 Columns 7 to 10
    1.2047    0.8725    0.6744    1.2186
zzephod said:
The $$y$$'s are $$\sim N(y,R)$$ with $$y=1$$ and $$R=1/10$$, so in Matlab code a sample of 10 $$y$$'s would be generated thusly:
Code:
ysamp =
 Columns 1 to 6
 Columns 7 to 10
Can you explain the plus one and divided by sqrt(10). I understand the randn.
If y was represented as \(y = 0.1k + \) noise, \(r = 0.1\), and we want 6 values, would it be
Code:
for i = (1:1:6)
     sampley = 1 + 0.1*i + randn(1,6)/sqrt(10)
end
I just realized this doesn't make sense because we will have 6 1x6 column vectors. I am not sure how to use this definition of \(y\).
Or would it be
Code:
for i = (1:1:6)
     sampley = randn(1,6)/sqrt(10)
end
and then where I use my sample ys (which is in a loop), I can augment them as
Code:
for i = (2:1:8)
     some stuff
     x(i) = ax(i) + K(i)*((y(i - 1) + (i - 1)*.1) - ax(i))
     some stuff
end
randn(nrows,ncols) generates a matrix of nrows rows and ncols columns of samples from a zero mean unit variance normal distribution.
Code:
-->Sample_Mean=1.0;
-->Sample_Variance=1/10.0;
-->ysamp=Sample_Mean+randn(1,10)*sqrt(Sample_Variance)
ysamp =
Columns 1 to 6    1.0032    1.0506    0.5366    0.9875    1.3739    0.7645
Columns 7 to 10    1.2047    0.8725    0.6744    1.2186
