Kapteyn's and Shapley's Milky Way - a comparison
The discussion compares the Milky Way models proposed by Kapteyn and Shapley, highlighting their methodologies and inaccuracies. Kapteyn's model, based on apparent brightness and proper motion of stars, estimated the galaxy's diameter at 55,000 light-years with the Sun positioned incorrectly near the center. In contrast, Shapley's model utilized globular clusters and Cepheid variables, resulting in a larger diameter of 330,000 light-years and a more accurate placement of the Sun at 65,000 light-years. Both models failed to adequately account for interstellar dust, which significantly affected Kapteyn's findings.
  • Understanding of stellar distances and apparent brightness
  • Familiarity with Cepheid variables and their significance in astronomy
  • Knowledge of globular clusters and their role in galactic structure
  • Awareness of interstellar dust and its effects on astronomical observations
  • Research the role of Cepheid variables in distance measurement in astronomy
  • Explore the impact of interstellar dust on astronomical observations
  • Study the characteristics and significance of globular clusters in the Milky Way
  • Investigate modern models of the Milky Way and their methodologies
Astronomy students, astrophysicists, and anyone interested in the historical development of galactic models and the methodologies used in stellar distance measurement.
Flucky
Hi all, new here and was wondering if you could help me out. I'm basically giving the two Milky Way models, and what was a common mistake (note it's a written piece not workings out) and I'd like to know if you think it makes sense/I don't waffle too much.
Thanks in advanceThe attempt at a solution
Kapteyn mapped his version of the Milky Way Galaxy using the distances of stars, using only apparent brightness for the stars too far away to have a measurable proper motion (he did however estimate the size of the galaxy using stars of known parallax and proper motion). His galaxy consisted of a disk of stars with a diameter 5.1 times greater than its thickness. With a diameter of 55,000 light-years, a thickness of 11,000 light-years and a total of 47.4 billion stars this was quite a small Milky Way. More importantly though, Kapteyn placed the Sun near the centre of the galaxy “lying between 2000 and 2300 light-years from it” which was very flawed.
Shapley however focused on globular clusters to measure the size of the Milky Way. In particular he looked at Cepheids which are yellow supergiants with set and reliable pulsation periods. He used these yellow supergiants in particular because they obey a relationship in which the longer the pulsation period, the larger the star therefore the greater its mean intrinsic brightness. With this knowledge and the ease of measuring apparent brightness he could easily find the distances to the centre of the globular clusters. Shapley's Milky Way was much bigger than Kapteyn's at 330,000 light-years in diameter. Realising globular clusters would form near the galactic centre he also placed our Sun much further away at 65,000 light-years, and even though the figures are incorrect (Shapley's model is agreed to be about two times too bigger than the accepted modern model) he was right in thinking the Sun was not near the centre of the Milky Way. One cause of the bloated figures is that what Shapley thought were Cepheids were in fact W Virginis stars, which are intrinsically fainter giving the illusion that they were further away than thought.
There was however something that neither astronomer took into account when mapping their galaxies, and that was interstellar dust. This meant that some of the light from distant stars was absorbed and so they would always appear dimmer to the observer, making them seem fainter and further away. Kapteyn even looked into interstellar dust and found evidence for its existence, but later dismissed the idea and he remained confident in his galactic model. Unfortunately for Kapteyn, who was mapping the galaxy using stars alone, the dust had a much bigger impact on his model. The dust was blocking the view to the true centre of the galaxy, which is why he was led to believe the Sun was so close to it. Shapley used clusters which are much more luminous than lone stars so could be seen at greater distances more clearly – also the majority of them are found outside the plane of the Milky Way, which is where the gas and dust is at its thickest. That combined with the use of pulsating variable stars to measure distances saw a more realistic model of the Milky Way.
milky bump
Note: delete this thread.
No longer useful.
Ta
  • · Replies 29 ·
  • · Replies 19 ·
  • · Replies 29 ·
9K
  • · Replies 30 ·
