MHB Kernel of Linear Map: Show $\ker \phi$ Equation
The discussion centers on demonstrating the equation for the kernel of a linear map $\phi: V \rightarrow W$. It establishes that if $v \in V$ can be expressed as a linear combination of the basis $(b_1, \ldots, b_n)$, then $v$ is in the kernel of $\phi$ if and only if the corresponding coefficients $(\lambda_1, \ldots, \lambda_n)$ satisfy a specific linear condition. The participants clarify that the condition for $v$ being in the kernel is equivalent to the coefficients being in the set defined by $\mathbf{L}$. Ultimately, they confirm that the representation of $v$ in terms of the basis and the condition on the coefficients correctly defines the kernel of the linear map. The conversation concludes with agreement on the correctness of the derivation.
mathmari
MHB
Hey! :o
Let $1\leq n,m\in \mathbb{N}$, $V:=\mathbb{R}^n$ and $(b_1, \ldots , b_n)$ a basis of $V$. Let $W:=\mathbb{R}^m$ and let $\phi:V\rightarrow W$ be a linear map.
Show that $$\ker \phi =\left \{\sum_{i=1}^n\lambda_ib_i\mid \begin{pmatrix}\lambda_1\\ \vdots \\ \lambda_n\end{pmatrix}\in \textbf{L}(\phi (b_1), \ldots , \phi (b_n))\right \}$$
I have done the following:
Let $v\in V$. Since $(b_1, \ldots , b_n)$ is a basis of $V$, we have that $\displaystyle{v=\sum_{i=1}^n\lambda_ib_i}$.
Then we have that $$v\in \ker \phi \iff \phi (v)=0_W \iff \phi \left (\sum_{i=1}^n\lambda_ib_i\right )=0_W \iff \sum_{i=1}^n\lambda_i\phi (b_i)=0_W$$
Is this correct so far? (Wondering)
Hey mathmari!
Yep. Correct. (Nod)
Btw, what is $\mathbf L$? (Wondering)
Klaas van Aarsen said:
Yep. Correct. (Nod)
The definition is: $$\mathbf L=\left \{(\lambda_1, \ldots , \lambda_k)^T\in \mathbb{R}^k\mid \sum_{i=1}^k\lambda_iv_i=0\right \}$$
So we get $$v\in \ker \phi \iff \phi (v)=0_W \iff \phi \left (\sum_{i=1}^n\lambda_ib_i\right )=0_W \iff \sum_{i=1}^n\lambda_i\phi (b_i)=0_W\iff (\lambda_1, \ldots , \lambda_n)^T\in \mathbf L$$
But to get the desired result it has to be $v=(\lambda_1, \ldots , \lambda_n)^T$, or not? So did we have to take at the beginning this assumption? (Wondering)
Yep. (Nod)
No. $(\lambda_1, \ldots , \lambda_n)^T$ is not an element of $V$, is it? And it shouldn't be. (Shake)
It's not an element of the kernel either.
Don't we already have the desired result? (Wondering)
What do you think is missing?
Yep. (Nod)
Ohh now I think I got it. I thought we have to show that $v\in \ker \phi \iff v\in L$, but $(\lambda_1, \ldots , \lambda_n)^T\in \mathbf L$ is just the condition that $v$ is in $\left \{\sum_{i=1}^n\lambda_ib_i\mid \begin{pmatrix}\lambda_1\\ \vdots \\ \lambda_n\end{pmatrix}\in \textbf{L}(\phi (b_1), \ldots , \phi (b_n))\right \}$, right? (Wondering)
So from $$v\in \ker \phi \iff \phi (v)=0_W \iff \phi \left (\sum_{i=1}^n\lambda_ib_i\right )=0_W \iff \sum_{i=1}^n\lambda_i\phi (b_i)=0_W\iff (\lambda_1, \ldots , \lambda_n)^T\in \mathbf L$$ we have that $v=\sum_{i=1}^n\lambda_ib_i$ is in the kernel iff $(\lambda_1, \ldots , \lambda_n)^T\in \mathbf L$ which means that $v=\sum_{i=1}^n\lambda_ib_i$ is contained in $\left \{\sum_{i=1}^n\lambda_ib_i\mid \begin{pmatrix}\lambda_1\\ \vdots \\ \lambda_n\end{pmatrix}\in \textbf{L}(\phi (b_1), \ldots , \phi (b_n))\right \}$.
Is this correct? (Wondering)
Is this correct?
Yep. All correct. (Nod)
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 23 ·
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 23 ·
