KIC 8462852 (dipping again in March 2018)
  • Context: Graduate
  • Thread starter Thread starter craigi
The discussion revolves around the unusual light curves observed from the star KIC 8462852, particularly focusing on the significant dips in brightness and potential explanations for these phenomena. Participants explore various hypotheses, including the possibility of local obstructing bodies, alien structures, and the star's own variability, while referencing scientific literature and media interpretations.
  • Some participants suggest that the smooth light curve indicates a single body transit rather than multiple bodies, leading to a significant drop in brightness.
  • Others question whether the obstructing bodies are local to KIC 8462852 or if they could be stray asteroids closer to Earth, challenging the assumption of them being in orbit.
  • There are discussions about the implications of a Dyson Sphere and whether it could obscure the star in a more regular pattern, with some humorously critiquing the idea of alien construction.
  • Some participants propose that the star itself may be variable, drawing parallels to other variable stars that were once classified differently.
  • Concerns are raised about the media's portrayal of the situation, particularly regarding sensationalist interpretations linking the phenomenon to extraterrestrial life.
  • Several participants emphasize the need to refer to scientific papers for constraints on the size and orbit of potential debris, arguing against the Dyson Sphere hypothesis based on these constraints.
  • Speculation about the nature of the obscuring object includes ideas about planetary rings and their potential to cause variable light blocking.
Participants express a range of competing views regarding the cause of the light dips, with no consensus reached on a singular explanation. The discussion remains unresolved, with ongoing debate about the validity of various hypotheses.
Participants note the limitations of current understanding, including the need for further analysis and the potential for misinterpretation of data. There are references to specific sections of scientific papers that provide constraints on the discussed models.
  • #61
DaveC426913 said:
It's been noted that the curve is not symmetrical, but what do you mean by diffuse on the sides?
I mean a transiting exoplanet tends to produce a light curve that looks like this:
A sudden, precipitous ingress and egress leveling out to become a flatter middle section - because the planet is a single mass, and it's either "all there" or all not.
The light curves from KIC 8462852 are the opposite: a smooth ingress and egress that instead of leveling out, drop down into a sharp point.
The shape suggests an object surrounded by a more diffuse cloud of matter, which is what it looks like in the gradient curves.
TLDR: What Bandersnatch said.
Astronomy news on Phys.org
  • #62
Artribution said:
In Photoshop, I converted the object's light curve into a gradient curve:
It's not exact, but it gives a rough approximation of what the light curve represents in visual terms:
Debris cloud? Or ships orbiting alongside the ringworld?
I see, so the leading edge is more diffuse than the trailing edge? The gradient has a very comet like feel to it indeed.
  • #63
Has any comet we've seen in our solar system created comas anywhere near that size?
Looking at the size of the star and the length of the orbit, it's right in the habitable zone right? Could a captured exoplanet make sense, or a moon that got knocked off of a bigger planet? An icy moon falling towards the inner system would act like a comet right? But it's greater gravity could hold onto it's coma better, and if it had a magnetic core, that could deflect some of the solar wind further reducing the erosion of the coma?
It's red dwarf orbits at about the distance of Plutoids, could it have thrown something the size of Pluto inwards?
  • #64
OK. I thought you were suggesting the curve itself was diffuse, as in you were seeing detail in it.
  • #65
I didn't notice that until now, but yeah, it's the leading edge that's longer, not the trailing edge.
I realize it doesn't really mean anything, but just out of curiosity, I made a more mathematically accurate gradient:
And applied a uniform blur:
And some enhancement:
  • #66
Are there any measurements of the stars doppler shift? I mean if there is a Dyson sphere orbiting the star it wouldn't really have much impact on the star. But as far as I know all the other explanations require huge amounts of masses orbiting the star, so they would surely leave a hint in the spectrum of the star.
  • #67
None of the considered scenarios require a large mass.
All measurements to date, including spectroscopy, are discussed in section 2 of the paper linked to in post #7. There's no indication of a massive companion to the star.
  • #69
That doesn't seem to fit where I'm at in my head. I look at it this way...
It gradually builds up the amount of light it blocks (very slowly, very small amount) then and "BAM" it blocks a huge amount of light for a very brief time and then more abruptly it disappears. like a quickly moving large dark companion with low mass so the star doesn't wobble. Hmm.
What about if the "cloud" is being acted upon by a magnetic field which aligns all the orientation to cause the particles to interfere destructively at a narrow angle to our line of sight?
Or a complex orbit which only passes our line of sight every so many orbits? If there was a huge black companion (dead star) revolving with a bright partner (attracted hydrogen how ever many millions of years later) would we be able to see such a quick orbit? Is there any such cosmological model of such a thing? I'm way out of my league here. :-P
  • #71
I finally read the paper, and the comet explanation sounds too reasonable :(. Sure, the size of the dips is massive, but it agrees with all measurements. It is also the explanation with the least promising outlook. There is some chance to see more dips within 1-2 years or in a few decades, but the star could stay without further dips forever now if the orbit is eccentric enough. The infrared emission from the comet fragments is going down fast, so I don't know if other telescopes (in particular, JWST in 2018+) are still sensitive to it.
Is the source data for the measured intensity available somewhere? It would be interesting to compare possible matter distributions to the observed light curve.
@Last Exile: It is ruled out in the paper. In particular, the light curve does not fit to the rotation period.
That does not make sense.
  • #72
It is accurate, though. The gradient spans the width of the image. You may need to adjust your monitor's brightness settings or zoom in closely to see it.
  • #73
Last_Exile said:
Has the possibility of starspots been completely ruled out?
http://blog.planethunters.org/2013/02/11/starspots-and-transits/
I don't think starpots were ever a serious consideration.
The periocity of the observed transits are on the order of 750 days.
The rotational periocity of the star is on the order of 20 hours.
  • #74
We missed a transit in April, when Kepler was nonfunctional. The next one is predicted to be roughly in May 2017. What's odd about the curves is that the first transit is so smooth and well defined, while the second one is so chaotically distributed. The two small dips at the beginning of the graph are a bit odd too. So from my understanding, the interesting bit is that a well defined object became diffuse and chaotically distributed, with no apparent IR signature. Then again, the universe is kinda large, you'd expect some coincidences here and there. But yeah comets from outside the system or the oort cloud make by far the most sense. Unless the ATA has something to tell us, I guess we're going to have to wait till 2017 to find out. ):
  • #75
A possible transit - for something in a 750-day orbit. If something is in such an orbit, then we'll see it again. That is unlikely, given the analysis in the paper.
With a broken up comet, all dips come from different objects so their different structure is not surprising.
  • #76
If you break up a comet, the fragments need to be pretty small to get enough surface area to block out a substantial fraction of a star's light. Somewhere in the 100um to 1mm ballpark.
  • #78
It's not enough to make the extent large. One also needs to make it dark. You can't get it dark enough with only billions or trillions of particles. You need a lot, and they need to be really, really small.
  • #79
DaveC426913 said:
Well comet Holmes might have done the trick.
To-scale comparison:
https://en.wikipedia.org/wiki/Comet_Holmes
http://www.space.com/4643-incredible...igger-sun.html
So it is reasonable to believe that the nearby passing star could've directed a comet from it's own system or the oort cloud (origin doesn't matter too much I suppose) towards Tabby's star, which is when it created a coma as it got close, then this coma was shifted around by gravitational/collision events and that's why it looks so chaotic in the second transit? This is pretty much the most reasonable scenario I can think of.
  • #80
Why do they need to be small?
Is it because, for a given mass, the smaller the particle size the better the light-blocking?
  • #81
The total surface area needs to be comparable to the star's area to block a significant amount of its light. If you take something with a comet's mass, to get enough area drives you to break it up into 100um-1mm sized objects.
  • #82
TurtleMeister said:
That lightcurve looks very similar (except for it's magnitude) to the one produced by KIC12557548
The difference is, KIC12557548 is far from certain to be periodic at all, and it's not sub-24 hour transit for sure.
(My own hunch is that KIC12557548 dimming events are not transits at all.)
  • #83
These may be starspots of a type we never seen before. For example, starspots which are pole centered.
  • #84
The paper authors suggest that all different transits are different fragments. No orbit, and chaos because every event is different.
You have to cover a large fraction of the whole star with spots to get 20% intensity reduction. Also, why should they be exactly pole-centered?
  • #85
"Why pole centered?", we do see pole-centered "atmospheric" phenomena, such as Saturn's polar hexagon.
Since Kepler did not see such dimming events on any other star, this star may exhibit some rare phenomenon. Maybe its starspots appear much rarer than on the Sun, but when they do, they cover nearly a quarter of poleward surface.
  • #86
Wouldn't a gigantic starspot create a huge amount of infrared? As far as I understand, starspots are formed when magnetic loops kink so badly that they extend beyond the surface. In order to make a huge sunspot, wouldn't you require an insanely huge magnetic loop and create a lot of fast moving, extremely hot plasma that would glow like hell in IR? Lots of objects create huge magnetic vortexes at their poles (pulsars, quasars, black holes...) but they're all huge.
Are there any models for how a star might behave it for some reason it had an inordinate amount of iron in it's core? The amount of iron required to create magnetic fields of that strength?
  • #87
If radiation spectrum is blackbody, then lowering of temperature would not increase any part of the spectrum. The peak moves to redder wavelenghts, yes, but intensity at any particular frequency still falls, it does not increase. See at 7:00 in this video:
  • #88
At those temps, iron is not ferromagnetic :D
As a rule of thumb, for stronger magnetic fields of stellar (and planetary) objects, you need faster rotation. Incidentally, this star rotates faster than one revolution per day.
  • #89
You're right, I forgot that in objects like that its metallic hydrogen that makes the magnetic fields, not iron. One revolution a day is not that fast.
I'm not referring to the spectrum of the star itself, I'm saying that starspots are caused by massive magnetic loops that break the surface. Along those loops plasma races around at incredible speeds. Once those loops unkink, all of that plasma gets released from the magnetic clutches of the star and gets ejected out into space (a solar flare.) If this star is constantly having magnetic storms so fierce that starspots can dim it's light output by 20%, it should be sitting in a vast cloud of hot gas, similar to if two planets collided with each other. Wouldn't it? I'm saying that you would be able to detect all of that plasma being thrown off of the star in the IR.
  • #90
Unfortunately, that's drifting into an area where
a] it requires the invocation of an unprecedented phenomenon - and even granting that -
b] it still requires some tortured explanations (such as smoothness and periocity) in even make it fit our fantastic phenomenon.
With that, all bets are off. We wouldn't go much farther off to posit billions of pixies holding hands in a maypole dance.
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 54 ·
9K
  • · Replies 55 ·
12K
