Kinematics problem from a competition: Will the 2 sliding boxes collide?
The discussion centers on a kinematics problem involving two sliding boxes and whether they will collide. The first box travels a distance of s1 = u²/(2μg), while the second box travels s2 = 4s1, leading to a total distance of s1 + s2 = 5s1. For a collision to occur, the condition s1 + s2 must be greater than or equal to S, resulting in the requirement u ≥ √(2μgs/5). This derived condition is not included in the provided multiple-choice options, indicating a potential oversight in the problem's construction. The conversation highlights the importance of quality control in exam questions.
Jim Alexandridis
two small boxes of rectangular parallelepiped shape are launched simultaneously against each other, with velocities of meters 𝑢1=𝑢 and 𝑢2=2𝑢, from positions A and B of a straight and horizontal trajectory 𝑂𝑥 lying in a plane. The distance between them is 𝛢𝛣=𝑠 and the coefficient of friction between each body and the surface is μ. Boxes will collide if:
a)u≥2√(μgs)/3
b)u≥1√(μgs)/3
c)u≥2√(μgs)/5
d)u≥3√(μgs)/5
This problem was on an greek physics competition on 10th grade and there is a disagreement about the answer, so i would like your opinion depending on my answer
Kinematics:
V=v0+at
Dx=v0t+1/2at²
Smax=v²/2a
The distance covered by the first box is :s1max=v²/2|a|=v²/2μg where a=-μg by second newtons law
Similarly S2max=(2v)²/2|a|=4v²/2μg
It gas to be s1max+s2max≥S => v²/2a +4v²/2a ≥s => 5v²≥2aS =>v²≥ 2μgS/5=> v≥√(2μgs/5)
But this is in the possible solution, am I wrong somewhere? I appreciate your help
Hi @Jim Alexandridis and welcome to PF.
The first box travels distance ##s_1=\dfrac{u^2}{2\mu g}##
The second box travels distance ##s_2=\dfrac{(2u)^2}{2\mu g}=\dfrac{4u^2}{2\mu g}=4s_1.##
The two boxes together travel distance ##s_1+s_2=5s_1=\dfrac{5u^2}{2\mu g}##
So what must be true for a collision to take place?
Sometimes multiple choice problems are not very well constructed.
Isn’t that the same as the OP did in post #1?
Yes. It's reassurance to a new user that when you're right, you're right.
I believe that for the collision to happen it has to be :
##S_{1}+S_{2}\ge S##
That is correct. As you already posted, this condition leads to $$u \geq \sqrt{\frac{2\mu~g~s}{5}}$$which is not one of the options (a) - (d). What you can do with this information is up to you. It ranges from doing nothing to bringing it to the attention of someone who is in a position to improve the quality control of exams like this.
Likes Jim Alexandridis
It might be a "copy/paste" issue. For example, in some other forum, I've just posted in LaTeX:
but after "edit and save" it has been converted to this:
