What is the minimum stopping distance for a car traveling at a speed of 40 m/s?
The minimum stopping distance for a car traveling at 40 m/s is calculated to be 100 m, which includes a reaction distance of 20 m due to a reaction time of 0.5 seconds. The acceleration required to stop the car was incorrectly calculated using two methods, leading to confusion. The first method used the equation vf^2 = vi^2 + 2ad with an acceleration of -10 m/s², while the second method incorrectly assumed a stopping time of 2 seconds, yielding an acceleration of -20 m/s². The correct approach involves recognizing the distinction between reaction time and deceleration time.
  • Understanding of kinematic equations, specifically vf^2 = vi^2 + 2ad
  • Knowledge of acceleration calculation using a = (delta v)/(delta t)
  • Familiarity with concepts of stopping distance and reaction time
  • Basic grasp of units of measurement in physics (meters, seconds)
  • Study the derivation and application of kinematic equations in real-world scenarios
  • Learn about the effects of different reaction times on stopping distances
  • Explore the relationship between speed, acceleration, and stopping distance in vehicle dynamics
  • Investigate how various factors, such as road conditions and vehicle type, influence stopping distances
Students studying physics, automotive engineers, and anyone interested in understanding vehicle stopping distances and safety measures.
habibclan
Kinematics-- Stopping distance
The minimum stopping distance for a car traveling at a speed of 30 m/s is 60 m, including the distance traveled during the driver's reaction time of 0.50 s. What is the minimum stopping distance for the same car traveling at a speed of 40 m/s?
vf^2 = vi^2 + 2ad
a = (delta v)/ (delta t)
Since the reaction time is 0.5 s, the distance traveled is 40 x 0.5= 20 m. Now, to find the time it takes to decrease the velocity to 0 m/s, one needs to find the acceleration whcih can be calculated in two ways and can someone please explain to me why the first way is incorrect!
Calculate Acceleration:
1) use equation
vf^2 = vi^2 + 2ad
I use the data for the initial velocity (first scenario) 30 m/s and the stopping distance 60 m, plug it into the eequation and i get -10 m/s^2. When I use this acceleration, vf (0 m/s) and vi (40 m/s) I can calculate d=80 m, which i add to the 20 m which it takes to react and the answer I get is 100 m.
1) However, if i use the equation, in which delta t= 2s - 0.5 s = 1.5 s. I subtracted the reaction time, the acceleration I get is a= (delta v)/(delta t) = (-40)/ (1.5) = -20 m/s^2. This acceleration is different from the acceleration calculated using the first equation. Can someone please tell me why this method is incorrect?
Thanks a lot!
Thanks a lot!
you've gone wrong here with your statement that delta t = 2s.
Where did this come from? If you are attempting to calculate the stopping time during acceleration in the first part of the problem, which itself is not correct, you should also note that the stop time during acceleration in the second part is not the same.
Oh right. That delta 2 was a stupid mistake as I divide the initial velocity by the distance to get 2 s :S which was just out of habit. Thanks for the correction! I get it now!
