Kirchhsoff's Circuit Law (Loop Rule Equation)
  • Thread starter Thread starter Pruddy
    Circuit Law
The discussion revolves around applying Kirchhoff's Circuit Laws, specifically the Loop Rule, to determine the currents (i1, i2, i3) in a given circuit. Participants are tasked with analyzing a circuit diagram and calculating various electrical parameters, including current through resistors and voltage across components.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants present loop equations derived from the circuit and seek verification of their correctness. There are discussions about the necessity of independent equations and the implications of sign errors in the equations. Some participants express uncertainty about the direction of currents and how to interpret the results.
Several participants have provided feedback on the loop equations and suggested that only two independent equations are necessary. There is ongoing verification of calculations, and some participants have shared their results while asking for confirmation. The discussion is active, with multiple interpretations and approaches being explored.
Participants are working under the constraints of homework guidelines, which require specific formats for answers and may limit the information available for solving the problems. There are also discussions about potential errors in calculations and the importance of maintaining precision in numerical values.
Pruddy
1) Please take a look at the attachment below in order to solve the problem. Using the figure at the right determine the values of i1, i2 and i3. Input your answers in the form "a.bc x 10^(y) A".2) Using the correct results from #1, determine the following. For A and B you must also tell if the current directions shown are correct. Give your answer in the requested format.
A. The current in the 10.0 resistor. Answer format: "abc mA, Y/N" . Y/N means choose Y if the current is as shown, and choose N if the direction of the current is not correct.
B. The current in the 4.5 V battery. Answer format: "abc mA, Y/N" . Y/N means choose Y if the current is as shown, and choose N if the direction of the current is not correct.
C. The voltage across the 15.0 resistor. Answer format: "ab.c V".
D. How much power is dissipated in the 5.0 resistor? Answer Format: "abc mW"
Loop: i1(10Ω) - 9.0V + 6.0 V - i3(15Ω+20Ω) = 0
Loop: i3(15Ω+20Ω)-i2(5Ω+12Ω) - 4.5V = 0
Loop: i1(10Ω) - 9.0V + 6.0V + i2(12Ω + 5Ω) - 4.5V = 0
Junction: i1 + i3 = i2
Please I would like to verify if my loop equations are correct and also to know how i can solve for i1, i2, and i3. Thanks a lot!
You have a sign error in the second loop equation. It has to be +.
Not all loop equations are needed. Only two of them are independent. Using two loop equations and the equation for the junction, you can solve for all currents.
ehild
Your 2nd Loop equation
Loop: i3(15Ω+20Ω)-i2(5Ω+12Ω) - 4.5V = 0​
is incorrect.
It would be correct if i3 was in the opposite direction.
To solve:
You only need two (any two) of the loop equations. (The third is redundant.)​
Use the junction equation to plug in (i1 + i3) for i2, everywhere.
You then have two equations in two unknowns. Use Algebra skills to solve that.
Thanks a lot for your reply.
I used the two loop equations to solve for i3, i2, and i1. Please Take a look at my work below...
i1 = (i3(15Ω+20Ω) + 3)/10
i1 = 0.3 + i3(3.5) ......eqn 1
i3(15Ω+20Ω)+i2(5Ω+12Ω) - 4.5V = 0
i2 = (4.5 - i3(15Ω+20Ω))/(5Ω+12Ω)
i2 = 0.26 - i3(2.06) ...eqn 2
i1 + i3 = i2
0.3 + i3(3.5) + i3 = 0.26 - i3(2.06)
i3(3.5) + i3 + i3(2.06) = 0.26 -0.3
(6.56) i3 = -0.04
i3 = -0.04/(6.56) = -6.10 x 10^(-3)
i1 = 0.3 + (-6.10 x 10^(-3))(3.5) = 2.79 x 10^(-1)
i2 = 0.26 - (-6.10 x 10^(-3))(2.06) = 2.73 x 10 ^(-1)
These are the answers I got for i1, i2, and i3. Please, will you check to see if my calculations and answers are correct. Thanks a lot!
I suggest keeping your numbers in exact form, by using fractions, or at least increase the accuracy by including more digits.
i1 + i3 = i2
Notice here that you are taking the difference of two numbers which are nearly equal.
That can produce a percent error that's rather sizable, because you have rounded off.
(6.56) i3 = -0.04
You can check the answers by substituting into the loop equations.
I get an answer for i3 of i3 = -6/170 A ≈ -0.005381 A
using substitution to solve i2 and i1, I get
i1 = ( -0.005381(15Ω+20Ω) + 3)/10 = 0.2811665
i2 = (4.5 - (-0.005381 (15Ω+20Ω))/(5Ω+12Ω)) = 0.2757844
using the information above, Please how do I calculate the current in the 10.0 resistor and How do i know the direction of the current. Thanks a lot... I appreciate.
  • · Replies 18 ·
