Lagrange Multipliers Question?
7 replies · 3K views · last reply
TheSpaceGuy
Find the minimum and maximum values of the function subject to the given constraint.
f (x,y,z) = x^2 - y - z, x^2 - y^2 +z = 0
Okay this is what I did:
Gradient f = <2x,-1,-1> Gradient g = <2x,-2y,1>
Gradient f = (Lambda) Gradient g
<2x,-1,-1> = L <2x,-2y,1>
2x = L(2x) L=1
-1=-L(2y)
-1=L(1)
by this Lambda = 1 and -1? How can this be, am I doing something wrong? Thanks for the help.
I haven't seen this terminology before, but are you sure it isn't Gradient f = - (Lambda) Gradient g?
In any event, look more closely at your first equation. What assumption did you make to obtain the value for L?
I checked and yes I got the formula right. To get my values for lambda all I did was set the two gradients with g multiplied lambda. This gives L = 1, -1. I don't know how to get the values of x , y , and z from this which is what I need.
I'm referring to the following step:
2x = L(2x) L=1
What assumption is implied about x and is the assumption valid?
There's a conceptual mistake here:
You have a function:
[tex]F(x,y,z)= x^2 - y - z[/tex]
and a vinculum which will be equal to zero:
[tex]G(x,y,z)= x^2 - y^2 +z[/tex]
build the Lagrange formula like this
[tex]H(x,y,z)= F(x,y,z) + \lambda G(x,y,z)[/tex]
Then take the partial derivatives and equal them to zero
[tex]H_x = 0[/tex]
[tex]H_y = 0[/tex]
[tex]H_z = 0[/tex]
[tex]H_{\lambda} = 0[/tex]
In doing all this you have missed one thing.
Hmm wow I didn't know you could do it that way. But anyway I figured out what I was doing wrong in regards to my method. I was assuming that x, y, and z were not zero. I can't automatically do that.
The two methods, [itex]\nabla F= \lambda \nabla G[/itex] and [itex]\nabla F+ \lambda\nabla G= 0[/itex] are exactly the same. They just change the sign on [itex]\lambda[/itex] which is irrelevant to the answer.
[itex]F= x^2- y- z[/itex] so [itex]\nabla F= 2x\vec{i}- \vec{j}-\vec{k}[/itex]
[itex]G= x^2- y^2+ z[/itex] so [itex]\nabla G= 2x\vec{i}- 2y\vec{j}+ \vec{k}[/itex]
[itex]\nabla F= \lambda\nabla G[/itex] becomes [itex]2x= 2\lambda x[/itex], [itex]-1= -2\lambda y[/itex] and [itex]-1= \lambda[/itex]. It does NOT follow from that that [itex]\lambda[/itex] is "both 1 and -1". In particular, the first equation, [itex]2\lambda x= 2x[/itex], does NOT mean [itex]\lambda= 1[/itex]. It means either [itex]\lambda= 1[/itex] or x= 0.
The last equation tells you that [itex]\lambda= -1[/itex]. Putting that into the second equation, [itex]-2\lambda y= 2y= -1[/itex] so that y= -1/2. Putting [itex]\lambda= -1[/itex] into the first equation, [itex]2x= 2x[/itex] we get, as I said before, x= 0.
Since we must have [itex]G(x, y, z)= x^2- y^2+ z= 0[/itex], x= 0, y= -1/2 give z= 1/4.
Yes, Halls of Ivy is right.
Thank you for the comment.
