Largest sphere radius that touches a wire in a cube
thereddevils
A 100 mm cube has a thin and rigid wire inserted 20 mm from each of two adjacent edges ,as shown.The cube contains a sphere that is not cut by the wire .What is the largest possible radius ,to the nearest mm, of the sphere that just touches the wire?
Some hints ?
  • Isometric diagram of a cube with a thin vertical wire passing through its top face, labelled 20 mm from two adjacent edges. Cube height labelled 100 mm. Marked NOT TO SCALE.
Some hints ?
Here's a top view, drawn to scale. That's my hint:
Geometry diagram of a circle inscribed in a square of side 100, with a dashed radius r from the centre, a diagonal, and a small 20 by 20 square in the top-right corner; labels 80 and 20 are shown.
Geometry diagram: a circle inscribed in a square, with a dashed radius r from the centre to the top-right point, a dashed diagonal, and a small corner square labelled 20 on top and right; bottom edge labelled 100, a horizontal segment labelled 80, and r marked horizontally from the centre to the left edge.
that's a great hint, thanks! I got r=47mm by phythagoras.
