Laser Output Modeling for Silicon Carbide Tile
Calculating the power density of a pulsed Nd:YAG laser for modeling surface temperature increase on Silicon Carbide tiles involves understanding average and peak power. The correct power density calculation yields approximately 2721 W/cm², significantly lower than the initial value of 6.165e9 W/cm². The project aims to visualize non-visible laser light using an IR camera, focusing on the thermal effects on materials like Alumina. Concerns about heat damage due to poor thermal conductivity of Alumina were raised, suggesting the need for better materials or cooling methods. The discussion highlights the complexity of laser-matter interactions and the importance of safety when working with Class 4 lasers.
mecheng2011
Hi guys, I'm new to the forum, I'm a mechanical engineer but running a project a little outside my comfort zone which is to do with optics.
I am trying to calculate the power density of a pulsed Nd:YAG laser but am getting in a muddle with the Average and Peak powers. The project is to model the surface temperature increase on a Silicon Carbide tile, when the laser is focussed to a spot of 0.53mm diameter.
I have used equations found online (http://www.newport.com/images/webdocuments-en/images/20063.pdf ) and am coming out with a value of 6.165e9 W/cm^2, which seems a bit excessive.
If you could let me know if I am on the right track, or where I am going wrong, it would be much appreciated.
Thanks
Alex
The laser details are:
Repetition rate: 20Hz
Pulse Energy: <300mJ @ 1.06um
Beam Divergence: <1mRad
Pulse Duration: 22ns
Hi mecheng2011,
Power density is simply (average power)/area.
Total energy in 1 second is 20 x 0.3 J = 6 J, so power is 6 W.
Area in cm2 is pi x (0.0265)squared = 0.002205 cm2.
Power density is thus 6W/0.002205cm2 = 2721 W/cm2.
That Newport link is good but you don't have to bother with peak power to get power density in W/cm2.
Can I ask what's the application?
Thanks. I was just getting confused as I am trying to model a single pulse, and I felt that maybe it should be somewhat higher as this is a Class 4 laser.
It is for a dissertation, I am basically designing a tool to convert non-visible light from Class 4 lasers (of the specification I wrote below) into something visible on a screen by using an IR camera. I am specifically trying to model this in Ansys, by using a section of target material, and applying a heat flux as a spot on it. I am trying to model for 1 pulse, and 1 second of pulse fire, and trying to see if the target heats up enough to be visible, or heats up too much and damages the material for both. I've been getting some ridiculous values, and my model seemed correct so assumed I must have made an error somewhere else- hence the issue of power density!
Perhaps from your experience, what would you expect, if using a ceramic material such as Alumina. Would you expect it to damage the surface quickly? I am very out of my field here with optics and lasers!
Thanks for your help
I readily see why it's class 4: http://en.wikipedia.org/wiki/Laser_safety#Class_4
The amount of variables determining the result of laser-matter interactions is impressive, and it does indeed occupy much of my professionnal time. The best way I can help you further is to refer you to my homepage, if ever your project involves experimental work. :smile:
The trouble with alumina is that it conducts heat very poorly. You might consider other materials with better thermal conductivity and/or actively cool the target (assuming it does get too hot). If you intend to use only a small time window, this may not be an issue. Keep in mind the safety issues of reflected IR light off the sample.
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
9K
13K
