How Does Le Chatelier's Principle Affect Reactions in Chlorine Water Systems?
  • Thread starter Thread starter Physicsrapper
    Principle
The discussion focuses on Le Chatelier's Principle as it applies to the reversible reaction of chlorine gas (Cl2) with water (H2O) to form hydrochloric acid (HCl) and hypochlorous acid (HClO). Adding HCl shifts the equilibrium to the left, decreasing the concentration of HClO. Conversely, adding NaOH neutralizes the acid, shifting the equilibrium to the right and increasing the concentration of chlorate ions (ClO^-). Mixing acid with bleach containing HClO is dangerous as it can release harmful chlorine gas.
  • Understanding of Le Chatelier's Principle
  • Knowledge of reversible chemical reactions
  • Familiarity with acid-base neutralization reactions
  • Basic chemistry of chlorine compounds
  • Study the effects of concentration changes on equilibrium in chemical reactions
  • Research the properties and reactions of hypochlorous acid (HClO)
  • Learn about the safety protocols for handling chlorine gas
  • Explore the applications of Le Chatelier's Principle in industrial processes
Chemistry students, chemical engineers, safety professionals, and anyone interested in the behavior of chlorine compounds in aqueous systems.
Physicsrapper
Cl2(g) + H2O(l) = HCl(aq) + HClO(aq)
(reversible reaction)
1. What would happen to the concentration of HClO if more HCl was added?
Wouldn't it decrease, since the position of equilibrium then would shift to the left?
2. If NaOH was added to neutralize the acid, what would happen to the concentration of CIO^(-) (chlorate I) Ions?
Wouldn't it increase, since the position of equilibrium would shift to the right?
3. What would be the best way to remove the smell of chlorine gas?
Wouldn't it happen by increasing its concentration? Because then the Equilibrium would shift to the right an it's amount would decrease...
4. What would happen if acid was mixed with bleach containing HCIO? Why would that be dangerous?
Can someone please explain the answers?
1. yes
2.
3. We don't want more Cl gas smell, we want less. So consider alternatives.
4. The equation shows what happens. Reaction proceeds from the right to the left, liberating harmful gas.
(I'm leaving 2 for someone else to answer.)
  • · Replies 20 ·
