djsourabh
- 69
- 0
1. If we drop an ice cube in a glass of water ,check the level of water & let it melt, what happens to the water level afterwards? Does it rise, remains the same or lowers?
The discussion centers on the effect of melting ice on water levels, specifically whether the water level rises, remains the same, or lowers after an ice cube melts in a glass of water. Participants reference Archimedes' principle, concluding that the water level remains unchanged after the ice melts. This is due to the fact that the volume of water displaced by the ice is equal to the volume of water produced when the ice melts. The conversation highlights the importance of understanding density differences between ice and water, as well as the negligible effects of temperature changes during the melting process.
PREREQUISITESStudents studying physics, educators teaching principles of buoyancy, and anyone interested in understanding the behavior of ice and water in practical applications.
djsourabh said:well I think it should lower.
adjacent said:Why?Use common sense and think.If you put something with a volume in water,would the total volume increase or decrease?
Tanya Sharma said:Are you trying to say volume of ice and molten ice is same ?
adjacent said:Volume of ice and water doesn't matter.Ice melts and it will increase the total water volume.If it is to decrease,Ice would melt to liquid of volumes -x.
Yes.And I said that in that post #6Tanya Sharma said:So according to you,after ice melts total water level should rise .Is that what you are trying to say?
adjacent said:Yes.
What?I don't see any reason why my answer is wrong.Please explain.Tanya Sharma said:In that case you need to study Archimedes principle .Your answer as well as your reasoning is completely wrong .
adjacent said:What?I don't see any reason why my answer is wrong.Please explain.
You are to compare the water level immediately after the ice cube is placed in the glass with the water level after the ice cube melts.adjacent said:What?I don't see any reason why my answer is wrong.Please explain.
Doc Al said:You are to compare the water level immediately [I]"after [/I]the ice cube is placed in the glass with the water level after the ice cube melts."
ehild said:It would happen if you forced the ice under the water level. But it floats, not the whole volume is immersed.ehild
djsourabh said:Please Elaborate. I don't think this would be easy question...We may have to consider the temperature of water before adding & after melting the ice cube...If its at 4 degree Celsius...ohh man this gets interesting...
While it is true that water displays anomalous expansion between 0°C and approximately 4°C, that's a very small effect compared to the amount of expansion that water undergoes as it transitions from liquid to solid.djsourabh said:Please Elaborate. I don't think this would be easy question...We may have to consider the temperature of water before adding & after melting the ice cube...If its at 4 degree Celsius...ohh man this gets interesting...
That's why the context matters. The context should be provided by OP.The problem does not say what time after the ice melts should you check the water level.
