LightCone Calculator Improvements
  • Level: Undergrad
  • Thread starter Jorrie
    Calculator
100 replies · 10K views · last reply
Cool! - it looks like we've got ourselves a workable calculator. :smile:
I have just pushed a small update that shows ##\Omega_M## and ##\Omega_R## on the conversion side, as discussed before.
Discrepancy between LightCone8 and LightCone7:
When comparing the outputs of LightCone8 and LightCone7, I noticed a discrepancy in calculated event horizon:
Table comparing LightCone8 and LightCone7 cosmology outputs at z = 0.00, with DHor Gly values highlighted in yellow: 1.443448807E+01 for LightCone8 and 1.654586113E+01 for LightCone7.
I think the value calculated with LightCone8 is questionable.
@Jorrie, @pbuk
It seems to be exactly the same as R, I'll have a look tonight (UK).
Interesting, I had started with the code from the last version of LightCone7 http://jorrie.epizy.com/lightcone7/2022-05-14/LightCone7.html and it gives exactly the same incorrect results. But when I use an older version of LightCone7 e.g. http://jorrie.epizy.com/Lightcone7-2021-03-12/LightCone_Ho7.html I get the expected results.
I have now added the correct calculation in the back end development branch, I will push this to the live site over the weekend along with the new UI.
No idea how that happened, accept that lots of experimentation happened around that time.
Anyway, thanks for the excellent work done by JimJCW and yourself.
@pbuk It happens in line 47 of your new calculate.js, where the mapping for Dhor is incorrect. Note Y (legacy) is the same as R later.
44 Y: entry.r,
47 Dhor: entry.r,
44 Y: entry.r,
47 Dhor: entry.r,
Yes, I picked this up from line 267 of the 2022-05-14 version of LightCone7
JavaScript:
          if (Dhor < Y)
              Dhor = Y ;
I removed the test because Dhor was never being set above 0 anywhere else in the code so was always being set to Y (r). This was because the line
JavaScript:
          Dhor =  a * (Dte-Dc);
which was there in LightCone7 2021-03-12 disappeared in the later version.
Let’s call
A: http://jorrie.epizy.com/Lightcone7-2021-03-12/LightCone_Ho7.html
B: http://jorrie.epizy.com/lightcone7/2022-05-14/LightCone7.html
and use PLANCK Data (2015) for the present discussion.
Result from A:
Line chart titled LightCone7 Chart plotting R (Gly), Dhor (Gly) and Dpar (Gly) against Cosmic Time (Gy) from 0 to 30; R rises steadily, Dhor rises steeply then levels off near 17, Dpar rises linearly and leaves the plotted range near 6 Gy.
Result from B:
Line chart titled LightCone7 Chart plotting distance in Gly against cosmic time in Gyr from 0 to 30. Orange Dpar line rises steeply and leaves the plot near 6.5 Gyr. Red Dhor curve rises and levels off near 17 Gly. Blue Ro line overlaps Dhor.
Note that Ro and Dhor overlap with each other.Comparing the Calculation.js files of A and B, I noticed that some statements in A are not in B: near Line 180 and Line 245. If we put the missing statements back to B:
pa = a_ic * sf;
////////////////*************Add the following missing line
a = a_ic + (pa / 2);
////////////////*************Found the problem
qa = Math.sqrt((Om / a) + Ok + (Or / (a * a)) + (Ol * a * a));
Dthen = 0;
////////////////*************Add the following missing lines
else
Dnow = Math.abs(Dtc-Dc);
Dthen = a * Dnow;
Dpar = a * Dc;
the modified B gives the following result:
Line chart titled LightCone7 Chart plotting Ro (Gly), Dhor (Gly) and Dpar (Gly) from 0 to 30 Gyr cosmic time on the horizontal axis and 0 to 20 Gly on the vertical axis; Dpar rises steeply and leaves the plot top near 6 Gyr, while Ro and Dhor curves rise and flatten near 17 Gly.
@Jorrie
Jorrie said:
Yes, correct. Is it something that you can fix on the calculate side, or must I fix it outside of calculate?
Fixed now. I've also tidied up the html (there were some extra empty <td>s and unmatched </tr>s) and bumped the version to 8.3 for the added CSV functionality.
I've pulled all these changes into the 'main' branch and changed the source for the live site back to 'main' from 'develop' for good practice.
Jorrie said:
Maybe cache problem
Oops, no it was me (updated the calculations, forgot to update the UI). Fixed now.
Since we now have a seemingly well behaved Lightcone8, e.g.
Line chart titled LightCone8 Chart plotting Selected Column graphs against Cosmic Time (Gyr) from 0 to 30. Ro (Gly) in blue rises steadily and levels off near 17. Dhor (Gly) in red rises faster and flattens near 17.5.
I decided to stress test it a little. By simply turning the knob labeled OmegaL down well below the stated minimum, namely to 0.0001, and expanding the range of the graph by trial and error, I've got this amazing result (from both a programatical and perhaps a cosmological POV):
Input and output parameter table of a cosmology calculator: Hubble constant 67.66, Lambda density 0.0001, radiation-matter equal redshift 3387, total density 1, upper redshift 200000, lower redshift -0.99, steps 100; outputs include present Hubble radius 14.455 Gly, future Hubble radius 1445.463 Gly, present time 9.632 Gyr.
Line chart titled LightCone8 Chart: Ro (Gly) in blue and Dhor (Gly) in red rise against Cosmic Time (Gyr) from 0 to 2,000; both curves flatten toward about 1,400 Gly, with Dhor rising faster early on.
If true, it shows the amazing performance of @pbuk's new calculation module and also the fact that even a relatively tiny OmegaL still points to the fact that the Hubble radius R0 and the cosmological horizon approach each other well beyond 2 trillion years.
Perhaps @JimJCW (our master tester) can advise us how far we can relax the input ranges before we run into gross inaccuracies.
😊 actually I'm pretty confident in the integration now: the functions become very smooth as ## t \to \infty ## and the integration uses the transformation $$ f'(x) = \frac{f \left (a + \frac{1}{1-t} \right )}{(1-t)^2} \implies \int_a^\infty f(x) dx = \int_0^1 f'(x) dx $$ to deal with the improper integral.
Jorrie said:
. . . how far we can relax the input ranges before we run into gross inaccuracies.
In LightCone7:
Input field labelled Lambda density parameter, Ω_L, containing the value .000000001, with a help icon and the range note '>0 to 1.00'.
In LightCone8.3:
Two form fields for the Lambda density parameter, Omega sub L. The first holds .0000000001 with the range '>0.001 to 1.00' beside it; the second holds 0 with the same range in red.
Note that in LightCone8.3, the range specification, ‘>0.001 to 1.00’, does not work. The specification in LightCone7, ‘>0 to 1.00’, seems to be more suitable.
In ICRAR, ΩΛ,0 can be set to 0 or a small value such as 0.000000001:
Set Variables panel with fields: z = 0, Sig Figs = 15, Reference Set = Custom, H[0] = 67.74, OmegaM[0] = 9.997034391e-1, OmegaL[0] = 1.000000000e-9, OmegaR[0] = 2.965599048e-4.
@pbuk
The test is simply that it is greater than 0 so the text should probably be changed, yes. Setting it to 0 seems to prevent the integration converging (probably because the Physics says it doesn't but I can't think exactly why at the moment).
Yes ##\Omega_\Lambda>0 ## is correct for the programming as it stands. I will change the input text.
When ##\Omega_\Lambda= 0##, there does not exist a cosmological event horizon - this is probably why the integration does not converge in that case.
While on the topic of stretching the input boundaries (ranges), a few others can possibly also be changed to allow for more broad comparison with other cosmo-calculators. I'm thinking of zupper up to a million and zlower to >-1, e.g.,
Table of input parameters for a cosmology calculator, with columns for Parameter, Input and Range, listing Hubble constant 67.66, Lambda density 0.6889, radiation-matter equal z 3387, total density 1, upper and lower redshift limits, and steps 1.
Any others?
Edit: possibly with a warning that a very high zupper may cause slow processing on laptops, tablets etc.
I don't think high z is a problem anyway, we already integrate to infinity to get ## t_0 ##.
For some reason I find a severe slowdown when starting z at 1E6, possibly because of the table that takes longer for larger ranges.
Perhaps the excessive slowdown for more severe ranges could be effected by the internet speed. As a test, I opened up the z range from -0.9999 to 1 000 000 and got between 10 and 15 seconds delay before the result table was presented. On my end I'm on a 50 Mbps fiber, but there are some intercontinental delays as well.
If I understand it correctly, your integration routine does not run locally, but on some remote server? If so, a large number of requests need to go to it, I guess.
For what it's worth, if it would be workable, it gave the following range in cosmic time:
Table with columns z, S and Tnow Gyr showing three rows: z 1.000000000e+6 with S 1.00e+6 and Tnow 7.533189823e-10; z 0.000000000e+0 with S 1.00e+0 and Tnow 1.378704250e+1; z -9.999000000e-1 with S 1.00e-4 and Tnow 1.730213490e+2.
That's from less than one year, way out to 173 Gyr...
No, it's all running in the local machine. I think the problem may be seeking too high a precision at extreme redshifts.
Where or how can I try the calculator?
The value z = 1000000 is unusual (I don't know why); it takes more than 10 sec to get my calculation result. For other values, such as z = 99999.99999, it takes only a fraction of a sec. You could change the range to,
> zlower to 99999​
I don't find z = 1000000 (1 million) to be special. It seems the calc time goes up exponentially with large z. Up to z = 300000 it seems to stay within 1 second execution time. This gives around 8 years after T = 0.
There is of course a different route that can be followed for times shortly after inflation, when radiation dominated overwhelmingly, i.e.,
$$H =H_0 (z+1)^2 \sqrt{\Omega_r}$$
(Edit2: sorry I had this upside down originally, as well as wrong in a silly way)
Not sure if it is worth the effort in coding though...
You are right; I mistakenly thought '99999' = '1000000 - 1'.
Jorrie said:
http://jorrie.epizy.com/docs/index.html
I'm still struggling to get a working link out of my fork for direct use on github
I have marked it v8.3.x
A recap on links:
The stable version (currently 8.3.0, incorporating CSV download, ## D_{hor} ## correction and the other changes we have discussed) is at https://light-cone-calc.github.io/.
@Jorrie your fork is at https://burtjordaan.github.io/light-cone-calc.github.io/, this serves whatever is in the docs folder of the main branch, which currently appears to be v.8.1.2 (although I think it is actually a bit modified from the "original" 8.1.2). But this code seems to be a bit behind what we are now working on (I think this was in the develop[ branch but that seems to have disappeared).
Calculator computation time:
The computation time of LightCone8 is discussed in Post #79-83, #86-88. For example, when the value of z is increased from 1 to 1000000, the computation time is increased from a fraction of a sec to 10 sec or so.
To get some ideas about this question, I did some experiments with the ICRAR calculator using PLANCK(2018+BAO) data and various values of z. The calculation times are all of the order of 1 sec. An example is given below:
Screenshot of a cosmology calculator with input fields for z (1e50), H[0] (67.66), OmegaM[0] (0.3110082030), OmegaL[0] (0.6889) and OmegaR[0] (9.179699026e-5), and results for redshift, expansion factor, luminosity distance, angular diameter distance and comoving volume.
@Jorrie, @pbuk
