Limit of ((a^p + b^p)/2)^(1/p) as p approaches 0
  • Level: Undergrad
  • Thread starter Thread starter arpitm08
    Infinity Power
5 replies · 18K views
arpitm08
one raised to the infinity power help please!
Let a and b be positive real numbers. For real number p define, f(p) = ((a^p + b^p)/2)^(1/p). Evaluate the limit of f(p) as p approaches 0.
By directly plugging in zero, you would get (1)^inf. Wouldn't that equal 1 or would it be something else? When I put it into my 89 i got 1 as my answer, but for some reason I don't think that it is right. Please help!
why wouldn't it? 1x1x1x1... is still 1 isn't it?
you can also check the graph at 0 to see if it converges to 1 when you plug in positive real numbers for a and b. don't the 89s take limits?
[tex]1^{\infty}[/tex] is undefined!
If a=b, note that the limit is "a".
Let then "a" be greater than "b", and rewrite:
[tex](\frac{(a^{p}+b^{p}}{2})^{\frac{1}{p}}=\frac{a}{2^{\frac{1}{p}}}({1+\frac{1}{N})^{\frac{1}{p}}, \frac{1}{N}=(\frac{b}{a})^{p}[/tex]
Then,
[tex]\frac{1}{p}=N\frac{\ln(\frac{a}{b})}{N\ln(N)}[/tex]
Therefore, you may rewrite this as:
[tex]((1+\frac{1}{N})^{N})^{\frac{\ln(\frac{a}{b})}{N\ln(N}}}[/tex]
which remains nasty..
"If a=b, note that the limit is "a"."
Indeed.
"Wouldn't that equal 1"
No.
That is what is called an indeterminite form.
further analysis is needed.
f(p)=((a^p + b^p)/2)^(1/p)
Let us consider an approximation that is exact in the limit.
a^p~1+p log(a)
b^p~1+p log(b)
if p~0
thus
(a^p + b^p)/2~1+p log sqrt(ab)
if p~0
(1+x)^(1/P)~exp(x/p)
if p~0 and x~0
by combining these the answer should be clear.
Hint: if your sequence is [tex]f(p)[/tex], consider the limit of the related sequence [tex]g(p)[/tex] where [tex]g=\log f[/tex]. Then use some standard properties of continuity.
