Limit on the edge of the domain
  • Thread starter Thread starter curious_ocean
    Domain Edge Limit
9 replies · 3K views
curious_ocean
What is the limit as x--> -5?
What is the limit on the edge of a function's domain?
What is the limit of the function as x goes to -5 (e.g. in the graph below) if the domain of the function is only defined on the closed interval [-5,5]?
I realize that the right hand limit DOES exist and is equal to 3, but the left hand limit does not exist?
So does that mean that the overall limit does not exist?
Or since the domain does not exist to the left, is the left hand limit not needed for the overall limit?
Thanks for your help!
curious_ocean said:
Homework Statement:: What is the limit as x--> -5?
Relevant Equations:: What is the limit on the edge of a function's domain?
Right. Only the right-hand limit exists at the left endpoint of the domain.
Right. For the limit to exist, both one-sided limits have to exist and be equal to each other.
I don't agree with this. If you apply the definition of the limit to that function, then the limit exists. The need for left hand and right hand limits to exist does not apply at an endpoint of the domain.
That's what I would say.
It depends on what definition you use, and whether you specify that only points in the domain can be used in the ##\delta-\epsilon## definition.
You can't evaluate a function at points outside its domain. This is basic set theory.
There are three quantifiers in the formal definition of [itex]\lim_{x \to a} f(x) = L[/itex]: [tex] (\forall \epsilon > 0)(\exists \delta > 0)(\forall x)(|x - a| < \delta \Rightarrow |f(x) - L| < \epsilon)).[/tex] The set over which [itex]x[/itex] is quantified must be some subset of the domain, or else we can't evaluate [itex]f(x)[/itex].
If you are given a domain which is an interval, then as far as you are concerned nothing outside of the closure of that interval exists. So the limit at an end point is necessarily the appropriate one-sided limit.
I would suggest that to be clear, the formal definition above should contain explicitly the statement that x is in the domain of f as a hypothesis of the implication, in addition to the hypothesis that |x-a|<d. I.e. it should read that "if x is in the domain and |x-a| < d, then.." This would render the explanatory next- to-last sentence unnecessary, and then the last sentence would be a logical consequence.
But [itex]x[/itex] must still be quantified over some set, and adding the condition that [itex]x[/itex] is in the domain to the premise of the implication adds nothing to the requirement that the set over which it is quantified must be a subset of the domain (and have [itex]a[/itex] as a limit point).
Let's put this concept to the test.
##f(x)=\mathbb{1}_{\mathbb{Q}}## is the indicator function of the rational- 1 if x is rational, 0 otherwise.
Is ##1/f(x)## continuous?
This was my point in post #4, in which I said it depended on which definition you used.
pasmith: Indeed it adds nothing if someone knows that you are quantifying x to lie in the domain, but you are assuming that someone will understand this implicitly because you have later written f(x). So I just suggest, for clarity, you make explicit what the domain of your universal quantifier is, i.e. I recommend putting "for all x in the domain of f" instead of just "for all x". I make this suggestion partly because I myself had trouble understanding clearly what you meant by your post. I.e. I at first took it for granted that your universal quantifier was "for all real x". Thus I assumed you meant the (omitted) statement "x is in the domain of f" to be understood in the conclusion of your implication, rather than the hypothesis.
Mark44: I was trying to second your comment. Indeed everything always depends on the definitions, so it makes no sense to ask whether something is true without giving the definition one is using for the terms involved. Many of us tend to assume everyone is using the same conventions and definitions that we are, and I think this is the basis of most misunderstandings.
Cheers!
