Limit Problems with Calculus: Solution Attempt and Explanation
  • Thread starter Thread starter Diffy
    Limits
6 replies · 2K views · last reply
Diffy
Two questions
lim as n -> infinity
(1^k + 2^k + ... + n^k) / n^(k+1)
and
1/(n+1) + 1/(n+2) + ... + 1/2n
Definitions of limits, laws of exponents etc.
Well I think I have them both solved but it seems too easy therefore I think I did something wrong or am missing something.
I think they are both zero.
The first one you can rewrite the term in the limit as
(1^k)/(n^(k+1)) + ... + (n^k)/(n^(k+1))
If you take the limit as n goes to infinity of each of these, then they all go to zero.
I am not quite sure I can do this, or argue this that way, but it is the only thing that comes to mind.
For the second question, I do the same thing. Take the limit as n goes to infinity of each term. Since they all go to 0 the entire limit goes to zero.
Please let me know if my reasoning is correct.
One quick santiy check -- use Excel to do a few examples of each summation...
Start with n=10, then cut and paste to make n=20, etc. Do you see a trend?
BTW, you will need a column for n, and a column for the numerator of the nth term, and a column for the denominator of the nth term, and a column for the quotient of the nth term, and then a sum over that last column down at the bottom.
Yea they don't look to be zero, the first one looks like 1/3 and the second one looks like... well I don't know with n = 200 it was like .69 and n = 300 it was over 1.
Can you please give me a hint on how to actually solve these guys?
You must have taken k=2 for the first one, right? They are both Riemann sums which become exact in the limit as n -> infinity. The first one is the integral from 0 to 1 of x^k. The second one is the integral from 1 to 2 of 1/x. The first one depends on k, but if k=2 it's 1/3. That's how I knew you used k=2. The second is ln(2)=0.693... Good job using Excel (yuck!). Very brave. Review Riemann sums and see how this works, ok?
Dick thank you very much for your response. I owe you one, how about next time you need Excel help I'm your guy!
Actually the once or twice in my life I've actually used a spreadsheet, I used Openoffice Calc. But I'm sure you can you can handle that as well. I'll keep you in mind.
