Limits of Otherwise Equal Summations Unequal Due to Indeterminate Difference
  • Thread starter Thread starter nobahar
    Difference Limits
The discussion centers on the confusion surrounding the limits of summations and the concept of "indeterminate difference." A proof is presented showing that if the limit of a summation converges to a value A, then the individual terms must approach zero. However, when substituting terms in the summation, the limit appears to yield conflicting results, leading to an indeterminate form of ∞ - ∞. Participants clarify that this indeterminate form does not provide a meaningful value and suggest that manipulation of the summation is necessary to resolve the confusion. The conversation highlights the complexities of dealing with limits and the importance of understanding indeterminate forms in mathematical proofs.
nobahar
Limit of otherwise equal summations is uneuqal due to "indeterminate difference"?
Hello!
I was working through a section on summation in a maths textbook because of a recent question I asked on the forum, and I came across something which is confusing. I am not sure if it is necessary, but here is the proof first of all:
If
\lim_{n\to{\infty}}\left(\sum_{i=1}^n a_{i}\right) = A
then the sum converges and a_{n}\to0 as n\to{\infty}.
It goes:
If S_{n} = a_{1} + a_{2} + a_{3} + … + a_{n} then
S_{n} – S_{n-1} = \sum_{i=1}^n a_{i} - \sum_{i=1}^{n-1} a_{i} = a_{n}
Taking the limit gives the required result:
\lim_{n\to{\infty}}(a_{n}) = \lim_{n\to{\infty}}(S_{n} –S_{n-1}) = \lim_{n\to{\infty}}(S_{n}) - \lim_{n\to{\infty}}(S_{n-1}) = A – A = 0
I tried the proof myself first, and instead tried substituting S_{n} – S_{n-1} in place of a_{i} in \sum_{i=1}^n a_{i}.
This gives:
\sum_{i=1}^n (S_{n} – S_{n-1}) = \sum_{i=1}^n \left(\sum_{j=1}^i a_{j} - \sum_{i=1}^{i-1} a_j\right)
If I take the limit at this point, it is my understanding that this is still:
a_{1} + a_{2} + a_{3} + … = A
However:
\sum_{i=1}^n \left(\sum_{j=1}^i a_{j} - \sum_{i=1}^{i-1} a_j\right) = \sum_{i=1}^n \sum_{j=1}^i a_{j} - \sum_{i=1}^n \sum_{i=1}^{i-1} a_j
And I think in the limit the difference between i and i-1 disappears:
\lim_{n\to{\infty}}\left(\sum_{i=1}^n \sum_{j=1}^i a_{j}\right) = \lim_{n\to{\infty}}\left(\sum_{i=1}^n \sum_{i=1}^{i-1} a_j\right)
This is where I’m confused. If:
was an actual number, say B, then
\lim_{n\to{\infty}}\left(\sum_{i=1}^n \sum_{j=1}^i a_{j} - \sum_{i=1}^n \sum_{i=1}^{i-1} a_j\right) = B - B = 0
And the equality in the limit for the following equation (equation *):
\lim_{n\to{\infty}}\left(\sum_{i=1}^n \left(\sum_{j=1}^i a_{j} - \sum_{i=1}^{i-1} a_j\right)\right) = \lim_{n\to{\infty}}\left(\sum_{i=1}^n \sum_{j=1}^i a_{j} - \sum_{i=1}^n \sum_{i=1}^{i-1} a_j\right)
doesn’t make sense (even though it is otherwise true), since
\lim_{n\to{\infty}}\left(\sum_{i=1}^n \left(\sum_{j=1}^i a_{j} - \sum_{i=1}^{i-1} a_j\right)\right) = \lim_{n\to{\infty}}\left(\sum_{i=1}^n (S_{n} – S_{n-1})\right) = A
That is, the lim on the LHS of equation * is A, whereas on the RHS it is 0 (if it produced an actual number, B, in the limit).
I figured that the reason the equality is otherwise true but not in the limit is because the RHS produces an indeterminate form, which I think is called the "indeterminate difference", and so the result doesn't mean anything (like 0/0 or infty/0, etc):
\lim_{n\to{\infty}}\left(\sum_{i=1}^n \sum_{j=1}^i a_{j}\right)\to{\infty}
Since:
\sum_{i=1}^n \sum_{j=1}^i a_{j} = (a_{1}) + (a_{1} + a_{2}) + (a_{1} + a_{2} + a_{3}) + … + (a_{1} + a_{2} + a_{3} + … + a_{n}) = na_{1} + (n-1)a_{2} + (n-2)a_{3} + … + a_{n}
Then:
\lim_{n\to{\infty}}\left(\sum_{i=1}^n \sum_{j=1}^i a_{j}\right) = \lim_{n\to{\infty}}\left(na_{1} + (n-1)a_{2} + (n-2)a_{3} + … + a_{n}\right) which \rightarrow {\infty}
Therefore:
\lim_{n\to{\infty}}\left(\sum_{i=1}^n \sum_{j=1}^i a_{j} - \sum_{i=1}^n \sum_{i=1}^{i-1} a_j \right) = “{\infty} - {\infty}”
Which, form my understanding, doesn’t mean anything, and you have to manipulate the summation to get it into a form where it does make sense. Such as:
\sum_{i=1}^n \left(\sum_{j=1}^i a_{j} - \sum_{i=1}^{i-1} a_j)\right)
Is this somewhat similar to what happens with L’Hopital’s rule, where there’s some “indeterminate form”, so no solution appears to exist when left in that form, but there is an actual solution (in the case of L'Hopital's rule, by using the derivatives)?
Any clarification appreciated, is my understanding anywhere near the mark? ...this took a long time to write!
I don't understand the part where you replace a_i with S_n - S_{n-1} and then put that into the original sum. It seems to me like you're doing something meaningless here as the sum takes values of i from 1 to n and you are plugging in S_n - s_{n-1} That is, you're taking the sum of that expression from i = 1 to i = n but there are no i's in it. I feel like perhaps you confused a_n with a_i since a_n = S_n - S_{n-1} Or am I just understanding you incorrectly?
Thanks for the response elvishatcher, and you're correct; my apologies. I meant S_{i}-S_{i-1} = a_{i} and then I use the LHS for \sum_{i=1}^n a_{i} to get:
\sum_{i=1}^n \left(S_{i} - S_{i-1}\right).
Do you see what I mean towards the end?, the two summations:
Are equal for any n, except in the limit; i.e. following is not true:
Since one gives:
And the other gives:
From my attempt at least. I tried to justify these results in the first post, I'm not sure if they are correct. I figured the 'inconsistency' was due to the latter being an "indtereminate difference" (I think that is what it's called), and therefore isn't saying anything that makes sese, in a similar way to 0/0, etc.
Your help is much appreciated.
Ah, that makes a lot more sense. I'm no expert, but it seems to me that you're correct about the problem being due to ∞ - ∞ not being a defined value. It seems like what you do to get the two different results is solid. Infinity's a kinda weird thing to deal with, and a lot of its complexities are beyond my current knowledge; but the 4th post down in this thread: https://www.physicsforums.com/showthread.php?t=162517 seems to say that you're right about ∞ - ∞ being an undefined/indeterminate/whatever (i'm not sure of the exact term that's appropriate) value, so it's not just equal to 0. That thread might be able to help you out a little more.
nobahar,
Whatever do you mean by \displaystyle \sum_{i=1}^{i-1} a_j \,, or did you mean to write \displaystyle \sum_{j=1}^{i-1} a_j \ ?
By the way, ∞ - ∞ is an indeterminate form. Depending upon the specific details of such a limit, a limit which is of that form may turn out to be anything, including possibly ∞ or -∞, or it might be that the limit does not exist.
Thanks for the link, it does address the question. It's reassuring that someone agrees with the method I used to get two different results, as ##\infty## seems like a tricky thing to deal with. Many thanks for the response.
Damn it! I did mean \displaystyle \sum_{j=1}^{i-1} a_j. That's two notation errors... I hope that's it. I copied and pasted where I could to save time (because it took ages and I am not well versed in writing in LaTex) and the error got carried over; I can't believe I didn't notice it, I should have used a letter that didn't look similar to i! Anyway, if I have understood what your saying, the ##\infty - \infty## form essentially says nothing - it doesn't say what the actual limit is or if it even exists: it gives no indication of what the 'true value' is, which "may turn out to be anything". Again, if I've understood correctly, you are in agreement with elvishatcher.
Thanks also for the response.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
