Line Styles in a Graph in MATLAB
4 replies · 2K views · last reply
Mentor
I'm trying to plot 5 periodic functions on the same graph in MATLAB and I can't seem to figure out how to do it correctly. The following code will work, except that I still need to change the line style for each line so that they are easy to tell apart.
Matlab:
k = 1;     %spring constant
w0 = sqrt(k);
z = 0;     %Used to count the elements of y, which is used in the for loops below.
%loop to plot a periodic function for 5 different values of r, the damping coefficient.
for r = 0:0.5:2
    w1 = sqrt(w0^2-(r^2/4));
    for t = 0:0.1:10
        z=z+1;
        %Performs the calculation for each data point.
        y(z) = exp(-r*t/2)*sin(w1*t);
    end
    %Performs the plot of each function for each iteration of the outer loop.
    plot(y);
    z=0;
end
According to my book, the command used to plot with a different line style is: plot(x, y, '--')
However, any time I try to plot the above function using a command similar to plot(x, y), I just get a blank plot.
I've also tried using:
Matlab:
t = 0:0.1:10;
plot(t, exp(-r*t/2)*sin(w1*t));
But this just gives me an error, saying that the inner matrices must match or something.
Any ideas?
Have you tried plotting one, using hold on; and plotting the next?
Drakkith said:
Matlab:
t = 0:0.1:10;
Any ideas?
It's giving you an error because the sizes don't match. Try specifying the t element you want for the particular plot. Or changing r/w1 to match sizes.
Thanks Student100.
I managed to figure it out right after you posted, lol.
Turns out I needed to use the matrix multiplication operator '.*' instead of just '*' when multiplying sin() by exp().
Once I changed that my plot(x, y) started working correctly and I could add in the logic to set the line style.
Matlab:
w0 = sqrt(k);
%Calculations and Printout
hold;
for r = 0:0.5:2
    t = 0:0.1:10
    y = exp(-r*t/2).*sin(w1*t);
    if (r == 0.5)
        plot(t, y, '--');
    end
    if (r == 1)
        plot(t, y, ':');
    end
    if (r==1.5)
        plot(t, y, '-.');
    end
    if (r == 2|| r==0)
        plot(t, y);
    end
end
legend('r=0', 'r=0.5', 'r=1', 'r=1.5', 'r=2');
xlabel('Seconds');
ylabel('Amplitude');
title('Amplitude vs Time');
hold;
Drakkith said:
Thanks Student100.
Matlab:
w0 = sqrt(k);
hold;
for r = 0:0.5:2
    t = 0:0.1:10
    if (r == 0.5)
        plot(t, y, '--');
    end
    if (r == 1)
        plot(t, y, ':');
    end
    if (r==1.5)
        plot(t, y, '-.');
    end
    if (r == 2|| r==0)
        plot(t, y);
    end
end
xlabel('Seconds');
hold;
Cool glad you figured it out. :smile:
Was trying to get it to run in my version, but was having some problems. :sorry: Finally just got it working so I could see what it was trying to do. New code is working pretty flawlessly here.
