Linear algebra : calculating the determinant
6 replies · 4K views
fluidistic
-1. Homework Statement
Let A and B be 2x2 matrices such that A²B=3I and A^T*B³=-I, where A^T is the transposed matrix of A, and I is the identity matrix.
Calculate det(A).
0. The attempt at a solution
I know I don't know how to approach correctly the problem, but I've tried something.
I know that the determinant of A squared times the determinant of B is equal to 9 and that minus the determinant of A times the determinant of B cubed is worth 1. From this, I can't reach the answer. And I've no idea about a different approach.
If you have an idea, I'd be glad to be its tester.
gabbagabbahey said:
What exactly is the question?:confused:
Oops you're right. The question is to find out det (A).
I edit the first post to make it clearer.
Okay, in that case you are on the right track ; basically you have 2 equations:
[tex](\det A)^2\det B=9[/tex] and [tex](\det A)(\det B)^3=1[/tex]
with two unknowns; [itex]\det A[/itex] and [itex]\det B[/itex]
How would you normally go about solving a system of two (non-linear) equations and two unknowns? Try solving the first for [itex]\det B[/itex] and substituting it into the second.
That's what I've tried to do, but I gave up because I made an error.
Well now you gave me confidence and I could reach a result : det (A)=[tex]\sqrt [4] {9^3}[/tex]. Thank you very much!
Unfortunately you still have an error; you should get [tex]\det A =9^{3/5}[/tex]
Oh well, that's maybe a bit too late for me right now. I just saw my error! Unforgivable, I wrote that [tex](det(A)^2)^3=det(A)^5[/tex] instead of [tex]det(A)^6[/tex].
I got it now. Thank you!
