Linear Algebra question: n x n determinants
The discussion revolves around finding the determinant of a specific n x n tridiagonal matrix, where the primary diagonal contains 'a' and the first and third diagonals contain 'b'. Participants express varying levels of familiarity with determinants and seek methods to approach the problem without expecting complete solutions.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss methods such as using the product of determinants of upper and lower submatrices, recursive formulas via cofactor expansion, and transforming the matrix into an upper diagonal form. Some express uncertainty about applying row operations to an n x n matrix without knowing its size.
The discussion is active, with various methods being proposed and questioned. Some participants offer guidance on potential approaches, while others seek verification of these methods. There is no clear consensus on a single approach, and multiple interpretations are being explored.
Participants note the challenge of working with a tridiagonal matrix and the implications of the matrix's size on the methods discussed. There is also mention of a miscopied problem statement that has since been corrected.
willworkforfood
I know what a determinant is and how to solve for it, but in the case of this n x n matrix on my homework, I'm at a complete loss as to how to even begin starting this. I don't expect anyone to work it out for me, just to give me a solid method for how to solve it and prove my method for the n by n case.
The problem states to find the determinant and prove our result for the n by n case for the square n by n matrix defined as:
https://oncourse.iu.edu/access/content/user/whoblitz/Filemanager_Public_Files/matrix.JPG
This is the square (n x n) tridiagonal matrix with 'b' on the first and third diagonal and 'a' on the primary diagonal. Thanks everyone for your help in advance :)
Call the upper non-zero submatrix for U and the lower for L. Then the determinant is the product of their determinants, i.e det(U)det(L)
Can anyone else verify if this method works and if so why? Thanks for your time, incredible.
This method will work.
say you have a matrix
[A 0] say A is n x n and B is m x m then you can write
[0 B]
[A 0] = [A 0] [I 0] so you're matrix is in the form of the product of these
[0 B] [0 I] [0 B]
two matrices. then you can use the product formula for determinants
det(AB)=(detA)(detB)
then and you know that
det[A 0]=detA and the same for B.
[0 I]
I miscopied the problem it would seem, it is actually a tridiagonal matrix rather than the one that previously appeared here. The picture above has been updated to reflect this.
I again have no idea how to do this problem, any and all help is appreciated as before :)
You can find a recursive formula by cofactor expansion. The expansion will be in terms of a, b, the determinant of the same type of matrix of size n-1, and the determinant of a matrix of size n-1 that is almost the same type except it has a b in the top left instead of an a.
But you know, I did the first few determinants on my calculator and I don't see a simple pattern. You might want to use a calculator to solve the recurrence.
try changing it into an upper diagonal matrix (a matrix where all entries below the main diagonal are zero) using these properties
1) interchange two rows which gives a sign change in the determinant
2) multiply all elements in a row by a nonzero scalar which multiplies the determinant by the nonzero scalar
and
3)adding to one row a scalar multiple of the other which leaves the determinant unchanged
then the determinant is the product of the diagonal entries. Don't forget about what operations you used on the matrix to turn it into an upper diagonal because you'll still need to change the determinant accordingly.
i.e. property 1 change the sign of the determinant everytime you interchange two rows etc.
How can I use row operations for the n x n matrix when I don't know how many rows there will be? I don't understand how that yields a formula for the n x n case.
sorry, i wasn't thinking for the n x n case. try using cofactor expansion and i think you'll start to recognize a pattern developing which should be able to help you.
Expand by minors using the first column (or, equivalently, the first row). You should see a recursive method for that.
Thanks everybody
  • · Replies 25 ·
