Linear Algerba - Finding linearly independent vectors
5 replies · 8K views · last reply
Moomax
Hi guys,
I am solving a problem in the form: (ATx=0 where A is a matrix of known numbers and I am solving for x. After performing reduction and multiplying ATx, I am left with the following equations:
-X1 + X4 - X5 = 0
-X2 + X4 = 0
-X3 + X4 -X5 + 28X6 = 0
From these equations, I am trying to find the linearly independent vectors however, I am not sure how to do this. I tried pulling out a linear book but I couldn't make straight forward sense of the procedure. Can anyone help me out? Thanks!
I may be missing the scampi for the bees, but those aren't vectors, they're parametric eqn's, which describe surfaces.
Solving these equations is equivalent to finding the intersection of the three surfaces. I count 6 unknowns and 3 eqns, in which case the solution will be a 3D relation.
I'm not sure where linear independence comes into it but if X1, ..., X6 are the components of your vector then like christianjb says you will only be able to fix a 3D subspace, where all vectors in it satisfy your equation.
If you just need one specific solution, try fixing X1, X2 and X3. You'll then be able to calculate X4, X5 and X6 from your equations.
Moomax said:
Hi guys,
-X1 + X4 - X5 = 0
So X5= X4- X1
-X2 + X4 = 0
and X2= X4
X3= X4- X5+ 28X6
= X4- (X4- X1)+ 28X6
= X1+ 28X6
So X5, X2, and x3 can be written in terms of X1, X4, and X6.
Now, take X11= 1, X4= x6= 0. Then X5= -1, X2= 0, and X3= 1. One solution is <1, 0, 1, 0, -1, 0>.
Take X4= 1, X1= X6= 0. Then X5= 1, X2= 1, and X3= 0. Another solution is <0, 1, 0, 1, 1, 0>.
Take X6= 1, X1= X4= 0. Then X5= 0, X2= 0, and X3= 28. A third solution is <0, 0, 28, 0, 0, 1>.
The three vectors, <1, 0, 1, 0, -1, 0>, <0, 1, 0, 1, 1, 0>, and <0, 0, 28, 0, 0, 1> form a basis for the solution space.
HallsofIvy is on the right track with what I mean. But I am still a little bit confused about the actual proceedure.
Like what made you simplify the equations the way you did? When I was playing around with them trying to simpify it never occurred to me to set them equal the way you did.
Also after that was done, what made you pick the variables you did to equal 0 while others equal to 1?
I was just "solving" the equations. It would be nice if we could solve the equations for specific numbers (in which case the solution space would be the trivial subspace, containing only (0,0,0)) but here we can't. So we do the best we can. Since there are three (independent) equations, we can solve for three values- in terms of the other three. In this problem, ANY three can be solved for in terms of the other three. I just chose the easiest.
As for setting one variable equal to 1 and the others 0, that guarantees that the vectors you get will be independent.
