Linear motion converted into rotatory motion problem
The problem involves a ballistic pendulum where an object of mass m is fired at a pendulum bob of mass M, resulting in a combined motion after collision. The goal is to find an expression for the initial speed v_0 of the fired object in terms of various parameters including mass, length, angular displacement, and gravitational acceleration.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using energy and momentum principles to analyze the problem. Questions arise regarding the calculation of height for potential energy and the assumptions about energy conservation during the collision.
Participants have explored different approaches, including the conservation of momentum and energy. Some have provided expressions for the initial speed and engaged in clarifying the steps taken to arrive at their conclusions. There is an ongoing examination of the assumptions made, particularly regarding energy conservation during the collision.
Some participants express uncertainty about the height calculation and the implications of energy conservation during the collision. The discussion reflects a mix of interpretations and attempts to clarify the problem setup and underlying physics principles.
rabiakhan.91
In a ballistic pendulum an object of mass m is fired with an initial speed v_0 at a pendulum bob. The bob has a mass M, which is suspended by a rod of length L and negligible mass. After the collision, the pendulum and object stick together and swing to a maximum angular displacement theta.
Find an expression for v_0, the initial speed of the fired object.
Express your answer in terms of some or all of the variables m, M, L, and theta and the acceleration due to gravity, g.
a figure is attached for better understanding!
please help! :(
v= rω, s=rθ, ω=θ/t
i have tried using the above examples but i don't know what to remove time since we are not asked to write in terms of time
Approach the problem from an energy and momentum point of view. Find final (maximum) PE, KE after the collision, KE before the collision.
that was helpful! but while finding the potential energy, how will we find the height?
Use a bit of trig.
i got the answer v = (2g(m+M)(L-Lcostheta)/m)^1/2
what do u think?
what do u think?
Rather than just give your final answer, describe how you arrived at your answer.
ok so i got the height as L-Lcostheta
the kinetic energy of the block is 0 and the kinetic energy of both of them at the heighest point is 0. so
1/2mv(initial)^2 = (m+M)g(L-Lcostheta)
then i just rearranged to find v
i am still a little doubtful about the height though
The height is just fine. But your assumption that energy is conserved during the collision is not.
umm but then how will we find the equations?
K.E before the collision is 1/2mvinitial^2
after the collision = 1/2(m+M)v^2 + mg(L-Lcostheta)
momentum is conserved so
mvinitial = (m+M)v
mvinitial = (m+M)v
Good. That's what you were missing.
Treat the motion as having two stages:
- The collision. Momentum (not energy) is conserved.
- The rise after the collision. Energy is conserved.
so momentum is mvinitial = (m+M)v and after rearranging it will be v= mvinitial/(m+M)
then energy is conserved after collision 1/2(m+M)v^2 = mg(L-Lcosθ)
then we will substitute the value of v from the conservation of momentum equation so it will be
1/2 *mvinitial^2/(m+M) = g(L-Lcosθ)
and then rearranging, vinitial = 2g(m+M)(L-Lcosθ) / m
correct?
rabiakhan.91 said:
... energy is conserved after collision 1/2(m+M)v^2 = mg(L-Lcosθ)
The PE side of the equation's mass should be (m+M)
o yes yes! sorry! so
the energy equation after substituting for v will be
[ (m+M) m^2 * vinitial ^2 ] /2(m+M) = (m + M)g (L-Lcostheta)
and then vinitial = [2g(m+M)^2 (L-Lcos theta)] ^1/2 / m
I didn't get that. Show all steps. At least show what you got for v.
since momentum is conserved, collision before the moemntum is = after collision
mvinitial = (m+M)v
we rearrange for v so v= m vinitial/ (m+M)
then energy is conserved after the collision so
1/2 (m+M) v^2 = (m+M)g(L-Lcosθ)
then we replace v after collision with initial velocity so we substitute for it from the first equation in the second equation
1/2 (m +M) [m vinitial /(m+M) ] ^2 = (m+M)g (L-Lcosθ)
we simplify it and (m+M) is cancelled
so it becomes
1/2 * (m vinitial)^2 / (m+M) = (m+M) g(L-Lcosθ)
then rearrange (m vinitial)^2 = 2g(m+M)^2 (L-Lcosθ)
then take the square root of both the sides and send m to the other side
vinitial = [ 2g(m+M)^2 (L-Lcosθ) ] ^1/2 / m
vinitial = (m+M) [ 2g(L-Lcosθ ] ^1/2 /m
hope this clears up a little
Clears it up a lot. Good work by you!
you have no idea how thankful i am of u!
u have helped me in return of no personal gain!
i am literally moved by your act of kindness!
thank you so so much!
hope all your problems(physics and otherwise :P) work out !
You are welcome. You wish will be shared by me, Doc_Al, and many others.
  • · Replies 19 ·
  • · Replies 21 ·
